Filling an Armstrong Lever Arm Shock
twas_brillig
I've got an original AH 'Bug-Eye' Sprite shop manual. Section H.8 Dampers reads:
"When checking the fluid level every 6,000 miles (10000 km) all road dirt must be carefully cleared away from the vicintiy of the filler plugs b efore the plugs are removed. This is most important is is absolutely vital that no dirt or foreign matter should enter the operating chamber.
The correct fluid level is just below the filler plug threads.
The use of Armstrong Super (thin) Shock Absorber Oil is recommended. When this is not available any good quality mineral oil to Specification S.A.E. 20/20 W is acceptable. This alternative is not suitable for low temperature operation and is deficient in various other ways."
I bought a litre of Motul 20 wt motorcycle fork oil, and you don't need anywhere near this amount.
The old oil stank, and there wasn't much of it.
Moving the lever around led to different levels; I filled to the bottom of the threads with the lever in the position leading to the lowest fluid level.
Note that the shocks are off the car.
Doug
T Filling for an Armstrong shock Spridgets 1
R question on filling rear shock....[armstrong] MG 3
D Filling Holes Austin Healey 21
steveg TR6 Cooling system filling Triumph 7
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
Gearhead_Garage Fuel backup while filling Austin Healey 24
D Location of gearbox/transmission filling area Spridgets 12
N Filling holes??? Spridgets 16
H TR6 Filling up the TR6, overflow? Triumph 6
T filling/flushing steering rack Spridgets 7
T Revised fuel tank filling strategy - re ethonal Triumph 5
TRMark TR4/4A Shorten the radiator filling neck on a TR4? Triumph 7
T over-filling the gas tank Austin Healey 30
R Filling overdrive oil on BJ-7 Austin Healey 5
BOBBYR Filling my O/D transmission Austin Healey 8
CCURTISS TR2/3/3A Filling TR3 Steering Box Triumph 10
B Filling SU Dampers? Spridgets 20
A Filling Coolant Spridgets 6
G Checking & filling shock absorber fluid Spridgets 9
Johnny Filling differential Austin Healey 4
DerekJ Gearbox oil level and over-filling Austin Healey 11
L Filling shocks MG 16
T Filling rear Bugeye shocks - any tips? Spridgets 7
G Filling a completely dry cooling system.... Triumph 13
M Filling up with Gas MG 11
Obtong Filling Steering Rack/Boots MG 6
K Filling a grease gun Restoration & Tools 9
G Squeaking Armstrong Shock Absorber Austin Healey 7
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
T Function - Armstrong Lever Arm Shock Spridgets 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
K TR2/3/3A Armstrong Lever Shocks Triumph 5
J Armstrong adjustable lever shocks Spridgets 11
AngliaGT Armstrong Siddley Parts Car Other British Cars 3
S 1953 Armstrong-Siddley Sapphire Other British Cars 5
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
glemon What do you put in your Armstrong lever shocks? MG 12
Z Girling/Armstrong lever arm shocks Spridgets 2
T Armstrong dampers - always replace in pairs? Triumph 3
Jayrz Armstrong Dampers Spridgets 10
Luke_Healey How to refill Armstrong shocks? Spridgets 34
tony barnhill 1953 Armstrong Siddeley Sapphire on ebay Other British Cars 0
Daimlerdb18 Armstrong-Siddeley - to buy or not to buy? Other British Cars 29
