DerekJ
My gearbox is leaking like a sieve but for reasons I wont go into the earliest I can pull it is the end of July. However I want to keep driving the car so a couple of questions.
1. How accurate is that dipstick - I also find it quite tricky to get an accurate picture of where the oil actually is on the stick.
2. If the LOW level is reached, how much oil is still in the box? How low is low - a quarter full? a half full? or virtually empty
3. To err on the safe side I want to keep topping up the box. Is there any danger from overfilling? bearing in mind the gearbox is going to be pulled anyway.
4. I saw on the Healey list that someone with a similar problem was going to add some 'leak sealing' type product normally used on automatics. Any comments on that? Can it do any harm?
thanks
thanks
