Speedi-sleeve for the gearbox rear oil seal
mgnewbie
I am about to pull my hair out!!! Its the second time and almost 2 weeks of waiting, and AGAIN I got a wrong size sleeve (99168).... :wall:
Does anyone know what size sleeve I should order for rear oil seal for the 80B tranny? The correct Speedi-sleeve part number would be great!!!
YB
Platinum
No ideas from me, sorry. Are you seeing evidence it NEEDS it?
mgnewbie
mgnewbie
Doc, the flange is pitted with a groove and worn. a new seal won't hold unless a sleeve is fitted. Here is a closeup of the ugly flange;
I have just returned another wrong size sleeve back to the supplier.... :wall:
I'll call bearing suppliers in my area tomorrow and see if I can take the flange down to their store and get it fitted...
YB
mgnewbie
mgnewbie
I don't have a caliper to measure the flange, so I used a ruler and sighted the bore of the oil seal. It's 1 and 9/16" or 1.563" which will be SKF 99156, but, I am not sure if this is the right size????? I may have to take the flange down to harbor freight and "borrow" their caliper. :cowboy:
Platinum
I have a Gaco number (M11061753/8) for the front (input shaft) seal but NO <span style="font-style: italic">rear</span> reference. :frown: Sorry!
Grantura_MKI
Buy a second hand flange with out the pitting and groove. An industrial supply house will have the correct size. But sure to apply joint sealer to the outside of the seal upon re-fitting.
Cheers,
D.
mgnewbie
mgnewbie
Thanks for the tips. I've just ordered the speedi-sleeve 99156 from amazon.com. It has a nominal diameter of 1.563". I will update if it fits the flange once I receive it. I am surprised neither moss nor VBL sell it with the seals.
PAUL161
If the internal diameter of the sleeve is too small, have a machine shop turn the flange down just enough so you can dry ice the flange and slip the sleeve on. Once installed that way, it'll never move. Or, you can have them turn it down enough to slip on a thick collar they made and then let them turn the collar down to the proper out side diameter. Saying all of that, a good used flange would probably be a lot cheaper. JMHO. PJ
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
Michael Oritt Speedi-sleeve p/n needed Austin Healey 7
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
Jim_Gruber Speedi Sleeve required for this application - Need advise! Spridgets 12
Michael Oritt Speedi-sleeve part number Spridgets 0
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
T SKF Speedi-sleeve p/n for tailend of transmission? Triumph 3
K TR4/4A Paging TR4nut re Timken speedi sleeve? Triumph 4
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
M Speedi sleeve question Triumph 7
lorendad Speedi-sleeve Triumph 10
budk1953 Speedi-sleeve Spridgets 11
MGTF1250Dave Speedi-sleeve for Timing Cover Seal Triumph 15
G Cheap[er] speedi sleeves Spridgets 9
tahoe healey CR Speedi-Sleve Austin Healey 5
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Lin Thermostat and blanking Sleeve question again Austin Healey 7
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
R TR6 bronze sleeve for release bearing Triumph 1
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
T TR4/4A Release Bearing Sleeve Triumph 0
K TR2/3/3A Clutch and Gearbox Sleeve Differences. Triumph 12
BoyRacer Top bows - plastic sleeve for socket Austin Healey 0
K TR2/3/3A When assembling a release bearing to the sleeve? Triumph 4
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
K TR2/3/3A What's the easiest way to remove the clutch release bearing from the bronze sleeve? Triumph 7
B TR2/3/3A TR3 Cylinder Sleeve Installation Triumph 10
B inner bushing sleeve on pin? Triumph 5
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
PatGalvin TR2/3/3A Wet Sleeve to Engine Block Deck Clearance, TR3A Triumph 4
W Suggestions on wiring sleeve Spridgets 3
M Cylinder sleeve protrusion Triumph 4
T Apple Hydraulics for M/C re-sleeve Triumph 11
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
I TR6 TR6 Trunion installation/stop sleeve help Triumph 4
dklawson Spitfire Spitfire - Trunion Bushing/Sleeve Clearance? Triumph 2
KVH Revelation Re Those Figure 8 Sleeve Gaskets Triumph 8
Basil Redi-Sleeve for Spitfire? Spridgets 6
ronzet MGA MGA 1500 Thermostat Blanking Sleeve MG 22
prb51 TR2/3/3A TR3 Dif Pinion seal and speedy sleeve Triumph 12
W TR6 TR6 Crank oil seal sleeve Triumph 4
P thermostat/blanking sleeve? MG 5
G Oil Seal Sleeve......This is getting to be a pain Triumph 0
Steve P. master brake/clutch re-sleeve...suggestions Spridgets 3
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
