Thermostat and blanking Sleeve question again
Lin
To Steve Gerow:
So I was reading through this old thread https://www.britishcarforum.com/bcf/showthread.php?90781-Thermostat-questions
because now that I am in Florida full time I think I want to make a thermostat change. Steve, you did quite the job of reporting on various modifications you made. What did you finally end up with? Are you running a 160 degree thermostat, 180 or something else? Fully sleeved/partially sleeved? If you used the sleeve were you able to successfully use a double gasket to compensate for the height of the sleeve rim as well as the thermostat?
Lin
DerekJ
A simple answer would be that in the hot Florida climate you should run with a 160 degree thermostat. The thermostat does not determine the temperature at which the engine runs at but is there to ensure that the engine heats up as quickly as possible and so restricts the flow of water to the radiator until this is achieved. In cold climates you want the thermostat closed for longer so would chose a 180.
Keoke
Madflyer
Derek Right on point it's time in the radiator and in the block. I have a 185 Deg. for cold weather. Normal temperature has a large meaning. You are at sea level different for cars above 4000 feet like me. Tuning, gas grades, fluid mix, oil weight, normal driving speeds ( highway as to stop and go ) all make your operating temp. You know your car run best at that temp. Your block can be over 300 deg your EX manifold can reach 500 deg. With todays fuels adding oil coolers fans bigger radiators are things that can work. The Radiator cap is many times over looked, You may have a bad or weak cap it may be 6 to 9 ponds you may want a 12 pound. Reason; water boils at 212 at sea level 50/50 water mix increases that but the rad cap keeps water from boiling at a higher temp above 212. The point is keeping fluid from boiling because steam can go to much higher temp. So what is bad about over heating a motor? Pinging or pre firing at cyl. motor oil is damage by heat so less lubricating adding to wear and vapor lock fuel to carbs. My test is your car should be able to idle at temp for ten minuets and not over heat at any out side temp. If it over heats then you have some thing wrong. Madflyer
John Turney
BTW, you notice how your temperature gauge goes to 230F? That's the boiling point of water at 7 psig, the same pressure as your radiator cap.
Healey Nut Thermostat blanking sleeve Austin Healey 13
ronzet MGA MGA 1500 Thermostat Blanking Sleeve MG 22
P thermostat/blanking sleeve? MG 5
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
Top Bottom
