Thermostat blanking sleeve
Healey Nut
Simple question , whats the idea behind adding the sleeve ?
TimK
If asking about the sleeve on the thermostat originally installed from the factory, The sleeve blocks the hole that allows the coolant to recirculate without going through the radiator until the thermostat opens. Without the sleeved thermostat, some of the coolant will be recirculated without going through the radiator even though it should. If asking about a sleeve instead of a thermostat, it slows down the flow of coolant to the radiator to allow time for good heat transfer.
Healey Nut
Healey Nut
Ok so if you use the sleeve you are forcing more coolant through the rad therefore cooler running ?
TimK
Yes
steveg
Healey Nut - you live in a cooler area. If your cooling system temps are OK in the summer without the sleeve, then no problem.
If your car doesn't overheat, then no problem. The recirculation is a benefit in the spring and fall when you need a quicker warmup.
I live in a hotter area, therefore want the recirc port blanked off when the thermostat heats up.
Keoke
Healey Nut
Healey Nut
It gets pretty **** hot here in the summer so If I can get the engine temp down a bit and not have to drive anticipating red lights and tucking my right foot away to drive left footed to give my overheated right a break then I will try it .
Radiators have been recored with more passes but summer driving is just not fun and I find myself jumping into the Aston beacause of the AC ....
Yeah I know it sucks having to take the Aston Martin instead :eek::eek:
RAC68
Hi All,
As Steve indicated, there have been many discussions on how to cool our Healeys during a HOT Summer and this has been an area of past discussion, as Steve has indicated, due to the high recent costs and scarcity of a Sleeved thermostat. Although I have a sleeved thermostat in my Healey to eliminate this issue, many in hotter climates have eliminated the thermostat altogether and just installed the sleeve to aid cooling. If you drive in a temperate or cooler climate, this may not be the best idea and combining the sleeve with a standard thermostat will take some modification (additional flange space) to allow both (thermostat/sleeve) to fit properly and tight under the hose bowl. Although this has not been a difficult task, its issues have been addressed in past threads and should be reviewed before attempting.
Keep Cool (not necessary to say with the coming COLD Vortex),
Ray(64BJ8P1)
Deleted member 21878
Healey Nut
there are a lot of threads here on ideas to help cooling. i tried them all. in fact i have one folder of pictures just from my attempts to keep my car cool. while each try may have helped the cause a little, nothing really made me feel better.... until i put a new core in the radiator. i went from a three core flat fin style to a 4 core modern accordian fin style. that seemed to lower my car 10-15 degrees in cooling. it was night and day. So if you have not done the radiator, i would recommend that first.
as far as the floor and hot feet. you can get foil faced, self-stick duct insulation from Lowes for a pretty cheap price. it is like 12" wide and i forget how long. roll back your carpet and stick it down. even though i put fat mat down in my car, i went back and added a layer of the duct insulation on the driver side. i also put a layer on the underside of the tran tunnel, plus carpet padding on the top. the only place i have felt that gets hot to me now is at the flap for the tran dipstick. that is just because there was only a rubber plug there. i have since cut a piece of carpet padding and put it over that spot under the carpet.
it gets pretty hot here also.
if you don't want to pull the tunnel, you can probably just take off the carpet and stick a layer of duct insulation right on top. it does help.
Keoke
Yep:
Healey Nut
I was caught in traffic at the BC border and my Healey heated. I have driven in Tucson AZ in the summer and it did not heat.
Healey Nut
Healey Nut
Healey Nut
Radiators have been recored and Dynamat is all over the floors and tunnel .
I just ordered an original thermostat sleeve off flea bay . Will pull the thermostat and give that a whirl .........
once spring finally arrives .......ok back to my igloo .
Patrick67BJ8
Hi All,
Ray(64BJ8P1)
MOSS sells a sleeved thermostat.
Lin Thermostat and blanking Sleeve question again Austin Healey 7
ronzet MGA MGA 1500 Thermostat Blanking Sleeve MG 22
P thermostat/blanking sleeve? MG 5
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
