Revelation Re Those Figure 8 Sleeve Gaskets
KVH
I ordered Figure 8 gaskets from Moss. They are steel shim material, or so it appears.
But in my Lower Gasket Set from BPN, those same Figure 8 gaskets are not steel, they are copper.
However, I measured the thickness of the gaskets with a micrometer. The copper ones in my Gasket Set are .0037" thicker than the steel ones, and that is almost exactly the amount of sleeve height clearance recommended above the block.
Why the difference in the gaskets, and doesn't that clearly mean the Moss gaskets are incorrect?
[It's fun being a worrier]
Don Elliott
IMO, if you have the liners projecting up above the engine block an extra 0.004" and you are planning to use the standard thick copper covered composite gasket that was the original type head gasket, I don't see (IMO) a problem as the new thick and somewhat soft head gasket will compress and you may actually get an even tighter seal between the top of the liner and the head.
The projection height of the liner about the engine block is very critical for those who race or rally a TR where a steel or copper gasket (which is like a piece of shim steel or copper) is used. It has virtually no compressability and therefore the projection height in this case is very critical.
martx-5
When I took apart my engine, it had copper Fo8s. The ones that I got in my kit were steel. They measured 0.016". I never measured the ones that came out, but the steel ones gave me 0.003"-0.004" height above the block. The steel Fo8s are virtually uncompressible, whereas I assume, that the copper ones would compress a bit. I don't think they would compress quite as much as the difference you are noticing.
The important part is how much the liners protrude when in place. I went through a 'dry run' to measure the heights before everything got gooed up with Wellseal for final assembly. I also remember talking to Ken Gillanders at British Frame & Engine and he mentioned when using the steel Fo8s to run your finger along the gasket on both sides, and you will find one side that has a burr on it. He says that the burr should face towards the block not the liner.
What are the thickness measurements of the two sets of Fo8s that you have??
KVH
KVH
Here are the measurements I have:
Copper: .0205
Steel: .0168 (same as yours)
Difference: .0037
martx-5
I've read that there are oversize Fo8s available, and I think that the copper ones you have might be those. I would 'dry run' the steel Fo8s and see what kind of readings you get above the deck. You just want the heights to fall within range, and whatever Fo8 does the job is the one to use.
TR3driver
Great Pumpkin - R.I.P
I just checked a very old (but unused) steel Fo8, and my mic shows it as .0162" Tried to check some others, but they were too rusty to get a good measurement on.
But the reason I've got steel ones left over is because I've always hunted down copper ones to use. The original steel Fo8 gaskets were supposed to be coated with plastic, but the steel replacements don't seem to have the coating.
AFAIK, the only oversize copper ones are made to order by Mordy Dunst, so I doubt you found them in a set.
billspit
I would call the guys at BPNW and ask them about the difference.
Also, what is the brands of the two Figure 8 seals. The kits sold by BPNW are usually the good ones.
TR3driver
Stumbled across this just now, while looking for something else. This is a factory service bulletin, dated December 1955. As I read it, the original, original Fo8 gaskets were actually composition (meaning at least partly fibrous material); then were changed to plastic-coated steel sometime before Dec 1955; when they were again changed to copper.
KVH
KVH
What a great piece of history. I figured Wellseal just meant something to seal a well, not Mr. Wellworthy's special formula.
Very interesting quote.
Andrew Mace Revelation about brake shoes Triumph 4
drooartz Modification Revelation Spridgets 17
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
middie Those dashed darned brake calper bolts Spridgets 6
D One Of Those Nights Triumph 4
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
