Gearbox Oil/Fluid/Grease
mylillooker
I've got a 79 Midget 1500. As you may remember, I had my transmission semi-rebuilt while I was swapping engines. Well, we put the whole thing back together w/o filling the gearbox, there doesn't seem to be an easy way to do this now.
If you know of one please tell.
An acquaintance <font color="blue"> (who's been known to bend the truth) </font> /ubbthreads/images/graemlins/tongue.gif says I can just lift it in the front, take off the gear shifter and pour it in there. He says it'll be slow going but it all runs into the gearbox.
Any truth to this???
Thanks,
Mario
john_j
You can't just take the gear lever/stick out, you have to take the whole remote off - 4 nuts on top of the box about 12" in front of the gear stick.
I think then you might be able to fill it up, although it's 20 years since a took one of those boxes apart so I'm a bit vague.
Anyway, there must be a filler!?! Does the manual not show one? Have you taken the rubber covers out of the tunnel (roughly by the drivers right toe on a LHD car). Pre 1500 cars have the filler just behind the rubber cover, but my recollection of a 1500 fails on that detail!
It can be filled from below using a pump oil gun, the fill plug is on the passenger side. Stop by NAPA and ask to them what you are doing and they should have a inexpensive version for you.
Ask Bill Tilford if they can be filled from the top.. or is he the guy you are referring to?
sparkydave
The filler is on the right side of the trans case. As Trevor says, a pump gun would do the trick. A funnel and long hose from the hood side would work too.
JimBrashear
Mario, the plastic bottle of gear oil has the pointed end - snip it off and connect a suitable length of 3/8 or so rubber tubing ( fuel line works for me ). Take the plug out the side of the trans. then put the end of the hose in there and squeeze until it starts weeping out. The level is the bottom of the hole. Of course the car needs to be somewhat level for this. By the way, are you about ready to roll? Keep us up, Jim B.
aeronca65t
And be sure that you use proper Gear Oil (I like the Redline Synthetic 80W).
Older Spridgets (such as 1275 cars) use 10W-30 motor oil in the trans).
mylillooker
mylillooker
First, let me quell any rumors that may be started w/this post... NO! I was NOT talking about Bill Tilford. LOL!!! Very funny Trevor!
Jim, I am about ready to roll or at least try to. I'm taking the day off work tomorrow to see what I can do.
I'll check the weight of the oil too.
Hey, can someone explain again about setting the crank mark to 0 on the timing indiator tab?
Mario
C Gearbox oil British Motor Corp 3
S Add ZDDP to gearbox oil? Austin Healey 29
Lin Gearbox Oil Austin Healey 4
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R Gearbox and Overdrive Oil Level Austin Healey 18
ckeithjordan TR2/3/3A Gearbox Oil Improvement Triumph 7
D gearbox and OD oil drips Austin Healey 23
B TR2/3/3A Gearbox/OD oil Triumph 12
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
C 3000 gearbox oil Austin Healey 4
K TR2/3/3A 70/90 Gearbox oil and Synchros degrading? Triumph 5
Lukens Best gearbox oil... with overdrive? Triumph 16
P Engine & Gearbox Oil Austin Healey 3
memphis Gearbox Oil Seal Austin Healey 9
memphis Gearbox Oil Austin Healey 15
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
mgnewbie Oil dripping from gearbox MG 5
nicko oil in gearbox Austin Healey 10
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
A Vexing gearbox oil leak Austin Healey 5
C Need info on gearbox and rear end oil for midget Spridgets 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
R Gearbox oil 100/6 Austin Healey 5
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
D Gearbox Oil Lotus 7
OregonTR4A Adding gear oil to the gearbox? Triumph 8
R gearbox identification help & required gearbox oil Spridgets 4
HEALEYJAG BN1 Gearbox oil Austin Healey 9
J Gearbox front oil seal Spridgets 8
Wana Gearbox and differential oil change Austin Healey 8
B gearbox oil Triumph 8
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Woodie gearbox oil Spridgets 13
C Gearbox Oil leak? MG 10
G Gearbox oil leak? MG 3
dkj313 76 gearbox oil MG 3
DerekJ Gearbox oil level and over-filling Austin Healey 11
Z Gearbox oil and other notes by chris dimmock Austin Healey 2
B Wedge TR8 Gearbox Oil Triumph 5
sparkydave Gearbox oil question Spridgets 4
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
TNMGB Checking/adding gearbox oil?? MG 34
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
S gearbox oil Spridgets 5
J Gearbox Oil Fill? MG 16
