MGB-GT Where is the gearbox oil filler plug on a 67 GT?
healey_100_s
Hello Gentlemen
Where can I find the gearbox oil filler plug on my 67 GT ( all synchro gearbox)
( have downloaded a photo in the Members Pictures - MG)
thank you
H
healey_100_s
I guess my 67 GT may not have a standard gearbox, it is all 4 speed synchro, hence the workshop manual hasnt helped me at all in locating the filler
thanks
PAUL161
Re: Where is the gearbox oil filler plug on a 67
If it doesn't have a dip stick, then it should have a fill plug on the side.
A thought just came to me, does your GT have a plug on top of the tunnel up by the firewall? If it doesn't, and you cant see a fill plug on the side of the tranny, then someone might have put a later model tranny in it with a dip stick and you can't access it. Sounds crazy but possible.
T TR4/4A A-type solenoid need a gasket where it mounts to the gearbox? Triumph 4
vping Where to fill Gearbox? MG 4
S where to get rover automatic gearbox MG 3
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
