Oil dripping from gearbox
mgnewbie
Can someone please enlighten me on what maybe the cause of oil drip from gearbox at joint with the drive shaft? It wasn't leaking before I changed the oil. My guess is that the seal is damaged or is it something more serious??? :cry:
When I was changing gearbox oil yesterday for the 1st time since I got the car, I opened the plug on the side of the gearbox and stuck my finger in and tried to feel if there is any oil, and I couldn't get my finger wet. There must have been only about a quart of dirty oil drained from the bottom drain hole.
After filling the gearbox with new oil, I parked the car in my driveway which has a slight slope, with the front higher than the rear, and after about a few minutes, there was a small puddle of oil on the driveway.
My question is, is it difficult to change the rear gearbox seal? Do I need to remove the gearbox from under the car to do that? Any advice would be most appreciated...
Here is the picture of the leaking oil.
Platinum
Looks to have been leaking a while before you ended up with it. You can change the seal with the box in place: Driveshaft down, remove the output flange and pry out the seal. Much easier to type than do, tho.
This is now into the area where you're going to need a plan... if you decide to replace the cam and lifters, the job is MUCH easier with the engine out of the car... that said, the gearbox ~should~ be removed with it. You can then split the two and renew front and rear seals of the box. At that point the clutch can be checked, throwout bearing replaced, things inside the box measured.
You see where this is going? :shocked:
Harbor Freight is gonna LOVE you! :jester:
mgnewbie
mgnewbie
Doc, Yes, I am getting sucked into a black hole... :jester: BUT I still want the CB. So, I will just replace the seal, and since the flange is probably scarred, so I will also order a sleeve. I will change out the camshaft, lifters and push rods to fix the problem with valves not lifting and get the car in good mechanical condition...then sell it to buy a CB.
Platinum
YEAH!!!
THAT'S what I wanted to hear. :laugh:
mgnewbie
mgnewbie
Built a flange nut removal tool (using an angle) and got the flange off the tranny. Marked the nut, the shaft and the flange so I can reassemble exactly the way it was before. It took 8 complete turns to remove the nut. The sleeve I got from the supplier is too lage! :eeek: so, now waiting for a new sleeve to arrive. The flange is scarred so a new seal will not work without the sleeve.
Platinum
Oh bother!
Well, as you are apparently able to engineer this stuff, YAY!! :laugh:
The earlier cars are actually simpler than the thing you're fixin' now. Steady on! :thumbsup:
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
MTribe oil dripping from carburetor Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
