gearbox identification help & required gearbox oil
recordsj
I have a 74 MG Midget that has a midget 1500 engine in it. It also has a Laycock type J overdrive in it. I am wondering where the gearbox came from and what year? On the side of the gearbox it has a cast marking of 22G1553 (but that could be just a casting part number). Any help?
Why I am asking this is that I want to find out what type of oil is needed in the gearbox.
R
recordsj
Re: gearbox identification help & required gearbox oil
I am thinking from other looking around and research that I actually have a spitfire transmission and overdrive. Does anyone have any info on what type of oil to put into the gearbox and overdrive?
Bugeye58
The Spit boxes use 90WT GL-4 gear lube. An alternative that is superior in my estimation is RedLine MT-90.
I ran Royal Purple synthetic in the race car.
Jeff
Morris
Check out this link:
https://www.brit.ca/~tboicey/midget/midget_overdrive.html
It should give you some good info on the overdrive conversion. This guy says he uses straight up 30wt motor oil in his overdrive tran. It may be worth asking on the Triumph forum. Those guys will be much more familiar with the spit overdrive set up.
wick
V
vagt6
Many folks use 30-weight, non-detergent oil in the Laycock gearboxes. The N-D oil resists "foaming" that may occur with meshing gears and shear forces present in transmissions. Foaming reduces the surface tension of the oil, which may lead to failures.
In fact, Quantumechanics, a well-known Laycock gearbox restorer in CT, will void the warranty on their reconditioned Laycock OD gearboxes if you <u>don't</u> use 30 weight, non-detergent oil.
I don't think the original Laycock gearboxes required N-D oil, but the modern lubricants are better.
You might contact John Esposito at Quantumechanics, there's an email "contact us" page on the website. Send him an email and ask, can't go wrong.
He has a lot of my money, so I trust him on these matters. /bcforum/images/%%GRAEMLIN_URL%%/angel.gif
Good luck with the OD, unusual for Midgets and tons of fun!
TR6BobNF Gearbox Identification - Help Triumph 5
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
T Unusual gearbox identification Spridgets 1
Michael Oritt MGB MGB gearbox identification points MG 1
M_Pied_Lourd Gearbox Identification Triumph 17
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
