Side-Shift Gearbox
AHS
Hi, I recently did a little modification to a BT7 side shift gearbox and was wondering if anyone else has experienced or fixed a similar problem. Hopefully this post will help someone else too.
The problem is when shifting into 2nd gear, the shift lever could overtravel just a little but and move the slider just enough to rub on the next gear and make a nasty grinding sound. Once you let go of the shift lever, it fell into the detent and you could drive fine with no noise whatsoever. If you were very delicate shifting slowly into 2ng gear until you feel the detent, it could be done noiselessly, but that's no fun. Another gearbox I know doesn't do the same thing at all, so maybe most don't.
So while I was replacing the carpet I decided I might as well replace the clutch and then open up the gearbox, the way things generally tend to get out of control. Since the shift rod slides forward for 2nd gear, I was able to make a sleeve to slip over the front of the rod that hits against the inside of the case and stops forward travel just about .010" farther than it needs to go to slide into the detent. Sorry I forget the exact dimension, but I may have it written in my book if you want to know. It should be shortened to fit exactly right and this is actually the 2nd one I made, the first time I cut a little too short and started over.
I know that the depth of the shift rod recess in the bellhousing also provides a limit to the forward travel, but my my measurements, it is way too deep to do any good.
While I was at it I also made a spacer to limit the 4th gear travel even though the gearbox had no overtravel problem for 4th. This spacer hits on a portion of the inside of the case that is half as-cast and half machined flat, so it may not work as well as the second gear travel limiter that hits only a machined surface. But I figured this modification can't cause any harm, and I really didn't want to find out later that I should have done the same for 4th gear given the short time it took to make.
Bottom line - it made the car much more pleasant to drive. No more worries about very delicate shifts into 2nd gear. Of course if you make these, the ends must be perfectly square. I used a lathe, but that's not the only way. You must keep shortening them until just a tiny bit more (I did .010") than the entire detent notch is visible when you look straight into the detent ball hole while in 2nd gear position. Also test with the detent ball and spring in place with pressure on the spring to make sure it seats solidly into 2nd & 4th gear positions. The picture below shows neutral position, and you can see the 2nd and 4th gear detent notches inside the case opening.
The steel sleeves are free to slide around, and are a small enough OD that they don't cause any harm with shifting into any other position. 5/8" OD works, or maybe it could be a tiny bit bigger. 3/4" won't work, unless machined thinner in the portion where the shift rods need to clear the other forks in certain positions.
BobHaskell
The recess in the bell housing should have a piece of hard rubber that limits the travel of the rods. I believe Leo Ruof uses a piece of linoliuem if the original piece is missing.
AHS
AHS
Thank you! it did not! Thant seems a simpler solution, but a bit harder to control precisely. Does anyone know the thickness?
C abutment collar retaining ring - 4-speed side shift gearbox Austin Healey 2
bighealeysource Side-Shift Transmission Austin Healey 13
F Austin Side shift transmission question Austin Healey 0
L Side shift transmission BN2 Austin Healey 0
B Side Shift v Center Shift Austin Healey 13
J Anyone have a side shift tranny to get rid of? Austin Healey 3
bighealeysource Removal of side shift trans side cover on BN2 Austin Healey 9
bighealeysource Tranny question on BN2 side shift Austin Healey 6
britndablood Side shift tranny with shifting issues Austin Healey 10
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
J Side shift non OD to OD transfer? Austin Healey 1
B Side Shift Transmission Latest Austin Healey 1
tahoe healey Center shift to side shift conversion Austin Healey 1
B Side shift Transmission repair. Austin Healey 15
K TR2/3/3A Side view mirrors again Triumph 8
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
Walter74 AH Spares Side Exhaust Austin Healey 2
R MGB side chrome installation MG 4
W Need advice on installing new side curtain glass Spridgets 1
kodpkd Side Curtain Windows Austin Healey 11
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
D Rear Seat Side Panels, BT7 Austin Healey 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
D BT7 Rear Side Panels Austin Healey 0
T MGA Unknow side screen MG 6
K TR2/3/3A "Clip on" style side mirror? Triumph 9
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R Grounding Side Lights Austin Healey 4
R bugeye side lights. Spridgets 0
R side light install Spridgets 2
HealeyRick BJ7 Side Window Alignment Austin Healey 31
Fanch00 Noisy Side Screens Austin Healey 13
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
madhouse 100-Six Side Curtains Austin Healey 8
R MGA MGA Headrest fairing for R/H side MG 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
S TR2/3/3A foot well driver side carpet Triumph 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR2/3/3A tr3 side curtains Triumph 4
Healey Nut Side Screens Austin Healey 12
