Would anyone care to share their technique on how to do the foot well driver side carpet? The indent has me. Last time I used spray clue and cut the carpet to size almost. I had the arc part on the door correct, but wheel well looked wrong. This time I am thinking contact cement the indent and then the come out from that with maybe 2 move brushed on contact cement forming and work out from the center. Let the carpet run large all the way around then trim to fit the door arch after the glue has set and any other areas.
This is my second attempt. I just ripped out the first attempt
thanks Steve
thanks Steve
