M
Member 10617
Like many of you, I carry around a deflated spare tire because otherwise it would not fit in the compartment. I have had a new foot-operated air pump in with it. I tested it today and found that it doesn't work. Walmart sells an old-fashioned stand-up T-type air pump that works very well, though a bit slow, but it is too large to fit into the spare tire compartment.
Just would like to know what kind of hand-operated air pumps others carry around with them, if they have the same situation.
BTW: I don't want to use one of those cans of "Fix-A-Flat" if I can avoid it. And with no electrical plug in the car, I can't use an electric portable air pump.
