TR2/3/3A TR3 engine hand crank
Got_All_4
Just got a engine hand crank. A bit on the rusty side so I plan on soaking it in some Evapo Rust then painting it. What color or finish were they. Mine would be for a 1960 TR3A.
Geo Hahn
I agree, black. And before you do restoration work you might want to confirm it is the right one for your car. I have seen at least 3 different cranks (possibly more) - the main difference is in the placement of that thick collar bit that fits into the guide.
Got_All_4
Got_All_4
Thanks I wondered about that. On early TR3s and 2s the guide is closer to the front of the apron. There was an early on on Ebay recently and the thick part was clearly towards the back of the shaft and closer to the crank handle. This one is suppose to be for a TR3A or early TR4. Anyway probably not going to use it for starting just addition for the tool kit. Maybe use it for adjusting the valves.
sp53
In high school, I had a 1965 Sunbeam Alpine with a hand crank. My buddy saw it in the trunk one day and said hey that is a hand crank I thought, what! but in those days those starters were more than they are now, and it got used because that was all I had when the original went out.
Geo Hahn
It's a spectator sport...
martx-5
I hand cranked a TR only once. It was in 1965 and the car was a '63 TR4. Its was a cold December night in Boston and I had to get my date back to her dorm from the fraternity house. The battery didn't have enough to crank the car over to start. I pulled out the choke, opened the hood, primed the carbs with the fuel pump and got the crank out of the trunk. It took a couple of tries, but it did start. There was a look of disbelief from the passenger seat. :cool:
DavidApp
Back in the 60s and 70s batteries went through a period at the end of their lives of barely turning the engine over in the morning but being Ok the rest of the day. Now they don't seem to fade out they work today and don't tomorrow.
So I would use my starting handle when my battery got to that point.
David
Got_All_4
Got_All_4
Great points and memories over a hand crank. I don't have a Lucas starter any more. Got tired of getting out and banging on the starter or rocking the car back and forth in gear to get it off the flat spot on the armature. I have a high torque starter but last year it did the spin thing twice. First time in 20 years. Might be glad I have the crank.
TomMull
My Lucas starters have been quite robust. I've still got the origanls with not much more than replacement brushes. Hand starting does require a bit of skill, strength and a well tuned engine, at least that's my experience. I've never been able to hand start mine cold although many have done it regularly. I'd suggest giving it a try before you count on that crank getting you out of a jam.
Tom
sp53
Yeh I remember the starting process being an alignment of few things. I would have the choke just right and then gently turn the motor over until I was right at the top of a compression stroke then just twist the crank with one hard snap, and it would catch and go and release the crank; like said the motor had to be tuned good.
I would say got all 4 that it sounds like from here your ring gear is rounded out on one of the starting points. 4 cylinders engines pretty much stop at 2 spots which are compression top points which are reflected onto the ring gear and the starter drive smashes there each time the starter is engaged .
bnw
A post of mine from May, 2011:
In 1966, I stalled my 1960 TR3 in the middle of a busy 5 way intersection in Chicago. My starter, of course, was junk. Just as the impatient drivers at all 5 stoplights were about to get on their horns, I jumped out of the car, hand crank in hand, stuffed it in the guide in front, brought it up on compression and gave it a quick snap. She lit up instantly ( I had done this before ) I jumped back in and proceeded to drive off to a melody of hoots, beeps and applause. THAT is why I've scrapped (sold) a perfectly good R&P. I was 18 at the time.
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Moosca TR2/3/3A "56 TR3 Engine Verification Triumph 17
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
T TR2/3/3A TR3 engine ground Triumph 9
O TR2/3/3A TR3 engine removal Triumph 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
A TR2/3/3A TR3 engine removal Triumph 9
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
