TR2/3/3A 1959 TR3 engine rebuild problems
mt10flyer
First post. I rebuilt the engine and am having a hard time getting it to run right - dang it.
Symptoms: Hesitates, backfires on initial acceleration no matter how I have it timed, and does not produce much torque.
Equipment: New everything in engine, new Pertronix Flamethrower dissy, new old style fuel pump, stock rebuilt SU's.
Data: Compression 135psi on all cyl, checked and recheck value clearance, vacuum measured off front carb just above nil at idle, approx 15in at rpm, centered jets and equal coordination observed during accel, equal vac at idle, mixture test ok, I know the timing marks on the crank and cam are correct.
What am I missing? Sheesh.
Oh...and thanks in advance.
David
CJD
Backfire out the exhaust or the intake? My most common mistake on a new rebuild is getting the wire sequence wrong.
mrv8q
Distributor 180 degrees off?
tr3aproj
Sounds like either ignition timing or cam gear is one tooth off. Have you tried substituting the points distributor for the petronix? That is what I would try first.
Robert
mt10flyer
mt10flyer
The backfire is through the carbs. At TDC the dissy rotor is pointing to #1. 1-3-4-2. I may throw the old dissy back on and see if that helps. The low vacuum reading at idle seems odd. Does anyone know what "normal" vacuum off of the front carb fitting should be?
I don't think the cam is a tooth off. When I aligned the marks on the cogs I turned the crank by hand several revolutions to verify that the marks came around and lined up properly.
sp53
Take note that at the Dissy cap the wires are not in a linear pattern. Pull the cap and look inside. Or perhaps the union that holds the two carbs together isloose
martx-5
Backfire through the carbs usually indicates lean condition and/or ignition timing problem or messed up firing order...assuming that the cam timing is OK. Could also be a vacuum leak as smaceng suggests (which would cause a lean condition).
mt10flyer
mt10flyer
Hmmm. Fuel starvation would have the same leaning effect. That is something I haven't considered.
CJD
Intake....my guess is firing order or cam. If it was really lean enough to cause the intake backfire, then it would be a bear to start cold. Backfire with lean will be under load.
Have you checked the valve clearances? A stuck valve or no valve clearance will cause intake backfires. After that, a large intake leak will do it.
mt10flyer
mt10flyer
Got it...and I AM a looser. It was firing order [hangs head in shame]. 1-3-4-2. Yup. No problem...but it is in the counterclockwise direction. On the MG rebuilds I have done I remember [perhaps falsely] the rotor going clockwise. Anywho, after getting it right she runs like a striped ass ape. Thanks for the help...and now you can make fun of me.
BillyB62
Don't beat yourself up - it once took me two days to find a bad ground! That's what we are all here for - to help each other when we get stuck and have questions. I'm in the middle of putting everything back together from my winter tear down......I'm sure I'll be posting for help soon!
CJD
Like I said...my most common mistake on rebuilds! Easy to confuse with everything going on getting it going. At least it's easy to fix!
MDCanaday
I guess the fuel pump is new....but is it one of the DEFECTIVE new fuel pumps out on the market???
On the original pump the factory pinned the pump arm into place.The new pumps the pin is dropped into
a grove and swagged over to hold it in.This can and does fail quite soon giving very low fuel pressure.
To check it while starting,pump the lever under the pump to bring the pressure up.If it runs fine for a few seconds
you have a turd on your hands.....
MD(mad dog)
C For Sale 1959 TR3 - Unrestored survivor car Triumph Classifieds 2
J TR2/3/3A My 1959 TR3 Endeavor Triumph 6
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
NutmegCT TR2/3/3A 1959 TR3 - dying starter? Triumph 4
S TR2/3/3A 1959 TR3 on eBay Triumph 1
CraigLandrum TR2/3/3A 1959 TR3 is alive! Triumph 24
J For Sale 1959 Morris Minor Convertible Other British Classifieds 3
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Hamish Racing TR2/3/3A 1959 TR3a used in anger Triumph 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
K TR2/3/3A 1959 TR3A For Sale on Ebay for $8,500...kurttannermotors Triumph 1
L For Sale 1959 Jaguar Mark 1 Jaguar Classifieds 0
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
S For Sale Sunbeam Alpine Factory Workshop Manual - All Models 1959 - 1968 Other British Classifieds 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
Z For Sale 1959 XK150 Absolutely Stunning Jaguar Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
angelfj1 TR2/3/3A Restoring Smiths heaters as fitted to a 1959 Triumph TR-3A Triumph 4
S TR2/3/3A Waking up a 1959 TR3A Triumph 10
J For Sale For sale: 1959 tr3a Triumph Classifieds 4
TRMark Craigslist 1959 Sprite Spridgets 3
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
B 1959 mk1 3.4l jag Jaguar 4
M Wanted Windshield 1959 tr3a Triumph Classifieds 3
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
L K&N filters on 100/6 1959 Austin Healey 6
LarryK TR2/3/3A Craigslist St. Louis under 1959 Austin, Jag, Triumph Triumph 2
69MGC 1959 Aston Martin DBR1 Other British Cars 1
M Announcing a Finished 1959 BE Sprite Spridgets 27
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
R 1959 3000 Clutch not engaging Austin Healey 17
S 1959 Traveller and 1959 Glasspar Avalon Other British Cars 1
T TR2/3/3A I just posted classified for sale ad on nice project 1959 TR3A Triumph 0
D September 1959 Radiator Tag Austin Healey 6
P Doors won't stay open [1959 100-6] Austin Healey 16
P New Purchase - 1959 100-6 Austin Healey 13
C 100-6 Mainshaft Replacement [1959] Austin Healey 7
C removal of transmission cover from 1959 100-6 Austin Healey 16
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
dougie Alpine Rally 1959 Austin Healey 2
NutmegCT TR2/3/3A My 1959 TR3a now for sale [ugh] Triumph 33
C 1959 100-6 Overdrive installation Austin Healey 4
