TR2/3/3A TR3 floor replacement. Engine in or out?
tdskip
Does it matter is the engine is in/out of the car when replacing the floorboards? She has slabs of sheet metal just resting in there now with a couple of tack welds.
I have the front apron and cross-brace off as well - does that matter?
Doors are still on and fit is good currently
Thanks!
alfa33047
I have replace floors both with the motor/trans in and removed. It is alot easier with them out, but it can be done without removing them. I place the car as high up on jack stands as possible so that I can access both top and bottom. If Gear oil, grease and gasoline are present, take precaustions. Once you have your old floors out, trial fit the new floors before you start welding, making sure exactly where you want them. The area where the firewall meets the front of the floor should slid forward under the firewall/footwell area, usually that area is rusted out. I prefer to spot weld floors in so that it is like it was originally attached. Good luck, Bill C, Mesa, Az.
apbos
In my reading and looking at other restoration pictures the engine is frequently out. However the tub should be braced and you will need to remove your doors. I'm leaving on vacation in minutes. I want a full report when I get back in 10 days as I'll be taking the floors on when I get back.
Paul
P.S. Is it not funny how everyone always talks about Rust-free Califonia cars!
Popeye
Bronze
Depends on how quick you are... my six month long floor panel replacement has been much easier with the body off the engine/frame/trans.
(It is a year-long b/c I found other rust... sills, etc.)
However, when actually welding the floor, I put the whole car back together to get the proper alignment. I welded maybe 25% of the floor like that, then picked up the car and finished the welding. I've got the body hanging from two chain hoists hanging off the garage trusses.
Good luck! It was my first time, and boy is the learning curve steep!! (But not too bad... just be patient.)
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
T TR6 TR3 - TR6 floor pans the same? Triumph 2
T TR2/3/3A Are Classic2Current TR3 floor pans good quality? Triumph 14
Psevins TR2/3/3A TR3 Floor pan Triumph 22
T TR2/3/3A TR3 trans cover to floor gasket Triumph 8
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
ekamm TR2/3/3A Original tr3 floor mats in place of carpet? Triumph 3
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
T TR2/3/3A TR3 floor removal Triumph 4
mountainman TR2/3/3A TR3 Floor Boards Triumph 13
G TR2/3/3A New TR3 floor pans & rockers Triumph 1
S TR2/3/3A Tr3 floor pan removal Triumph 5
S TR2/3/3A new guy here....replacing floor TR3 Triumph 5
martx-5 TR2/3/3A TR3 Trunk Floor Triumph 0
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
