TR2/3/3A TR3 floor / frame mounting point question
tdskip
Hi guys - I was picking at the TR3a today (yes, shocking, I know) and noticed the DPO kinda of made a mess of the body to frame mounting.
How should these look? How would you recommend addressing this?
Thanks!
CJD
Are we looking at the ends of cut-off bolts? The body mount doesn't look that bad to me, but I am having trouble seeing what's going on with the bolt holes.
John
AEW
If the pad is removed, do the threaded holes in the frame extension line up with the bracket holes on the sill? I take it you are doing the floors while the tub is mounted. You might weld a thin plate over the sill between the floor to pretty it up since the stamping of the floor pan is not a critical contact. The bolts hold it all together. That center rust hole is where they touch. On the whole I might just clean it and paint it *. Really, with new floors it is not going anywhere. The bad thing I think would be if the frame extensions are rotted at their tube supports.
* these are just the thoughts of another future DPO :smile:
T
tdskip
No - they don't, which is the concern as they should.
CJD - these were taken looking down at the mounting point from above. The floor to body mounting bolts should screw in there there (I believe).
Is there a pad between the top metal part of the sill and the frame? Might that be what is under the holes? I've not take the body off one of these yet, so forgive the question.
TexasKnucklehead
Oh. I see a little of your floor is missing. That section of the sill should have 4 holes, but the floor will only have 2 holes that align to the threaded holes in the out rigger of the frame. If you push that little pad around that is sitting between the sill and the rigger, you should find the holes -hopefully without broken bolts in them.
The tub should move around enough to align the holes.
CJD
There are pads. That's why I say I can't see what we're looking at. It could be the rubber pads are just slid so their holes do not line up with the holes in the mounting tab. With the floors removed, the body will have some ability to twist, so that can also account for a mis-alignment.
It does all need to line up so you are satisfied before the floor pans are even tacked into place.
John
T
tdskip
John
Hi John - but the bolts have to pass thought the four openings, right?
AEW
Just to add to the points made by all, these are a couple of pictures of a scrap tub I was cutting up last year. Note the distance between the original floor and the sill bracket. The floor contour reinforcement is about 5/8 inch deep. There are only pads under the sill bracket, the two layers of metal above just sandwich together.
T
tdskip
Hi guys - thanks for the coaching here.
So in the picture above the floor mounts to that sill structure, correct?
If so, then as suggested, I have some packing/mount materials from the old floors sitting on top of that in my pictures, correct?
Do I just cut that off/back to the sill structure in the picture above?
Thanks, and sorry for being denser than usual on this (insert joke here:______)
CJD
Like I said, I am having trouble from your pics seeing exactly what you've got going on. It appears the rubber may be stuck underneath and blocking the holes on the mounting plate...but it's really hard to tell without poking at it with a screwdriver or something. It also kinda looks like maybe seam filler could have gotten all over it...like a putty filler.
I think you'll have to clean it up and see what is left when you are done...
John
HerronScott
I agree as well that it's tough to tell from the pictures. Almost looks like someone's attempt to repair the mounting plates.
Scott
CJD
Got bored, so sat here looking over the photos.
I am guessing that some PO squirted seam filler between the floor pan and the inner sill body mounts. It looks like the filler spread out all over the mount. But, it does not look like the mount is rusted at all, which is great. I even think you can see the rubber pads underneath, just off center. It appears the mounting bolts were never installed after the seam filler was added. Perhaps to stop the rattle from not having the bolts in??
Anyway, it will be interesting to see what you find when you clean off all the goop.
John
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
T TR6 TR3 - TR6 floor pans the same? Triumph 2
T TR2/3/3A Are Classic2Current TR3 floor pans good quality? Triumph 14
Psevins TR2/3/3A TR3 Floor pan Triumph 22
T TR2/3/3A TR3 trans cover to floor gasket Triumph 8
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
ekamm TR2/3/3A Original tr3 floor mats in place of carpet? Triumph 3
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
T TR2/3/3A TR3 floor removal Triumph 4
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
mountainman TR2/3/3A TR3 Floor Boards Triumph 13
G TR2/3/3A New TR3 floor pans & rockers Triumph 1
S TR2/3/3A Tr3 floor pan removal Triumph 5
S TR2/3/3A new guy here....replacing floor TR3 Triumph 5
martx-5 TR2/3/3A TR3 Trunk Floor Triumph 0
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
