TR2/3/3A TR3 engine build
jdavis
Member
actually the motor is from an early 4A. I have a couple motors to choose from for my 59 TR3A project, but the 4A engine turns easily and is complete. I've never done a wet liner engine before. I've built a couple of TR6 engines and a couple of small block Chevy motors over the years, and mostly, they held together. I've dismantled the engine, and am in the process of ordering some parts. The main pins looks like it is .20 thou under, and the crank pins are 10 thou under. I'm going to take the crank to a machine shop and see how out of round it might be before I order bearings. One of the con rods is obviously slightly bent. The corresponding cam lobe is a bit pitted, although the lifter looks fine. I've got another set of straight con rods I can use. Otherwise, I think I have a good pIatform from which to start, I've read a lot about these engines, and I'm confident I can build a good reliable engine. I'll have lots of questions from those of you who are willing to offer advice. The car is just for fun. I have no aspirations to do anything with it other than play with it. I know I need all the major internals including a new piston/liner set and cam. My question for the day is: If money is no object (of course it is) Is there any reason NOT to go with 89 mm pistons? Rimmer brothers has an AE 89mm set for basically the same price as the 87mm county brand that TRF sells, and only slightly more than the other brand 87mm piston/liner that BPNW and Moss sells. I figure the more displacement, the better I plan on increasing the compression only slightly, and using a 270 degree cam. I have a header, and I will do some porting on the head. Any advice about the 89mm AE piston/liners would be appreciated. I see that most of the vendors sell a head gasket to use with the larger displacement set. Are there any other problems?
Joe
M_Pied_Lourd
Hi Joe,
Good luck with the engine build...take some videos :cool:
I think that I have read that one of the negatives of going to the larger Pistons/liners is a hotter running engine. That coupled with the header might give you some pretty hot temperatures under the bonnet so you may need to consider how you are going to cool it down as well. I believe I have 86 mm in mine as an FYI
Cheers
Tush
TR3driver
Great Pumpkin - R.I.P
Don't forget, the TR4 has a different front plate. You'll want to build with a TR3 plate.
In addition to possible cooling issues (some have em, some don't), you'll also pick up some compression ratio with the bigger liners. You might want to check combustion chamber size.
bobhustead
Aother thing. I thought my crank and cam sprockets looked good and fit well to the new chain. So I only changed the chain. 3500 miles later, I had to replace the sprockets (and chain) when the chain started hitting the cover. A major job when the body is together.
Bob
DavidApp
Did you determine what caused the chain to hit the cover?
I did the same thing, just changed the chain as the sprockets looked fine.
David
doc50
jdavis, to add to TR3driver's comment, if you DO find you've installed a TR3 engine with a TR4 front mount, simply jack up the plate off the mounts and remove about 1.25" of the lower part with a sawzall then weld the old mount base plate onto the 'shortened version'. That works. (...Don't really want to talk about it...but did it).
Thom
1959 TR3
#34909L(O)
charleyf
New cam should get new lifters. The 4A head will have the lighter 5/16" stems on the valves (better). You should get hardened seats in the valves . I use the 86 mm pistol because it gives me more distance between the coolant passages and the combustion chambers. I have had two head gasket failures even with the 86 mm Pistons.
though parts do add up I prefer to spend the money up front and get a reliable engine rather than gamble and pay later.
Charley
Frank_D
My engine was rebuilt 2 years ago after a crank failure. I went with 89 mm's and a slightly more agressive cam. Head was perfect so did not have to be machined. I was concerned about compression ratio but it has all gone well. We went with the lip rear seal, vernier timing gear and the engine was balanced, ARP head bolts, new lifters etc. I have an OEM rad with the crank hole and have had no heating issues for normal driving. In traffic with excessive idling, the temp does sneak up just like every other TR. Have not dyno'ed the car to determine power, but the torque is there well past 3500. Very quick car now. Watch out Tush!
wifegonnakillme
Hi Joe, as Tush asked, if you could post pictures or video along the way, it would be most appreciated. I have to start a rebuild in the near future and while I have been all around the motor, I've never opened one up. If it helps, my supplier in Canada gave me a detailed parts list (Moss) that I would be happy to forward on,
Good luck,
Kerry
M_Pied_Lourd
:cool: You will have to drive mine to compare!
Cheers
Tush
TR3driver
One thing I learned the hard way is to always check liner protrusion on both sides! Twice in a row now, I've found that the liner tops are not square to the block surface (apparently the block is not machined just right), and one side is low. Of course, I was always checking the other side ...
Of course, the right solution is to have the block machined; but this "shade tree" solution has served me well for a lot of years now.
Tinkerman TR2/3/3A How to build an engine run in stand for 60 TR3 Triumph 9
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
Moosca TR2/3/3A "56 TR3 Engine Verification Triumph 17
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
T TR2/3/3A TR3 engine ground Triumph 9
O TR2/3/3A TR3 engine removal Triumph 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
A TR2/3/3A TR3 engine removal Triumph 9
