Crank super hard to rotate by hand
boxfullofyertoys
I'm hoping someone can provide me with some insight on this one, as I'm now officially worried:
I was in the process of replacing the connecting rod bearings, and I had to rotate the crank by hand in order to get to the rods for cylinders 1 and 4 after completing cyls 2 and 3. When I went to do it, the crank was unbelieveably hard to rotate...even moreso than when I rotated it at the onset to start working. Whereas before I used both hands, this time it was 2 hands plus bracing my legs against something solid.
The spark plugs are pulled, the new bearings were lubed with assembly lube, and everything was torqued to spec (50ft-lbs on the rods, 65ft-lbs on the center main (pulled it to check for wear). The new bearings were a direct replacement (old ones were standard sized, new ones are as well).
Granted, I was on my back/under the car when I was turning the crank, and was probably a bit tired, but it seems to be <span style="font-weight: bold">a lot</span> harder than it was. Was it possible my uber-low oil pressure was being caused by loosened bottom end bits? Of the bearings I replaced, only 1 of the 4 I considered to really need replacing. The rest were in good shape, as was the crank.
Any input would be great, as I'm worried about trying to start the engine with it being as tight as it seems...
Thanks!
ralph_s
Somethings not right, you gotta go back and check the bearings and caps. Something is reversed! Should turn over by hand easily.
Spridget64SC
Check to see if a cap is on backwards. I've done this before and the engine would not turn. The locating tangs of the bearing will put marks on the rod parting surface where they line up. This will help tell you if a cap is on backwards if the rod is not marked for orientation.
Also double check the markings on the backside of the new bearing shell. I have had one wrong sized bearing show up in a package many years ago.
HTH,
Mike Miller
MikeP
Besides what's already been mentioned you should get some plastigauge and check clearances that way. It's possible you could have an undersized or mismarked shell and the only way to be sure is to check the fit dry.
boxfullofyertoys
boxfullofyertoys
Doh!
Well, this is a bit embarrassing...but I think I've already solved my problem without even knowing it...
I did the initial swap on Sat/Sun, and after re-reading the instructions Sunday night, I realized that there was a possibility I had put some of the caps on backwards. Yesterday I got under the car and checked them. I double checked cyls 2 and 3 first because they were easier to get to, and then rotated it to do 1 and 4. That's when I noticed the rotation issue. The only one that was installed incorrectly was cyl 1, which I then fixed. Once everything was torqued down, I cleaned up and quit for the evening, not even considering the backwards cap was the culprit.
The only other possibility is that I reinstalled the center main backwards, however I'm 99.9% sure that it came straight down, got looked at, and went straight back in the way it was. It was off for all of 2.5 minutes. I'm also pretty sure the bearings were all the same size, as I cleaned the h3ll out of them before they went in, and didn't see any odd size markings that caught my eye....but who knows right?
I guess when I get home tonight I'll get a wrench on the crank bolt and see if that was the culprit.
Looking back, I probably should have made that connection :wall:
The more I learn, the less I seem to know...
Thanks for your help guys!
ralph_s
Sounds like you might be on the right track. If it's still hard to crank, some plastigage will tell you if bearings & caps are to spec.
Same thing goes for the main caps, the bearing keeper tangs go on the same side. Also did you by any chance repalce the thrust washers, sometimes new thurst washers come of the box too thick and can cause a crank to bind and A series engines hardly ever wear the thrust bearings.
boxfullofyertoys
boxfullofyertoys
I haven't done the thrust washers yet. They're next up, along with a new oil pump. The issue with the crank was so blatant that I couldn't consciously move on without making sure I was good to go with the rod bearings.
I'll definitely keep an eye out for fat thrust washers when I put them in. I know they're a weak spot on the 1500, so I figured I'd do them with the rod bearings to ensure everything was kosher :smile:
Bayless
Plasti-gauge is your friend.
boxfullofyertoys
boxfullofyertoys
Just thought I'd update everyone:
I'm an idiot. I guess my frustration blinded me a bit. I went home the other night, got under the car, and sure enough I still had the cap on cylinder 3 reversed.
Flipped it around, and now she spins properly.
Thrust washers, oil pump, and a cleaning/repaint of the oil pan are on tap for this weekend. Just knowing that I've personally seen/repaired the the bottom end takes a huge weight off my shoulders.
I'm hoping now I can relax a bit and turn the radio up when I finally go for a drive this weekend :smile:
Thanks again for all the help!
jlaird
Always seems to take a few trys to get it right. In my garage anyway.
Falkon
Just curious, since im still having a bit of the same problem. How exactly do you know in which direction do the caps for the bearings face. What ever markings there were on the bearing caps and piston connecting rods are gone and the only ones that still exist are the numbers stamped into the sides of the caps and bottom of the rods.
jlaird
That should work, numbers on the same side. Should also be (maybe) a mark or set of marks cut into the rod and the rod cap. like I, II, III, IIII
Falkon
Well i do have all the numbers facing the same direction. And when i did try to turn the pistons around to face the numbers the other direction it wouldn't even fit back in. So i know the rods and pistons are facing the correct direction, rings are properly gaped, numbers in the correct order and direction, and the correct bearing sizes. Other than that i don't know what else it could be. The engine does turn easily but with a small wrench on the end, it just doesn't turn easily by hand. Maybe its just the fact that there are so many new pieces in it and they have yet to be worn in.
Deleted member 8987
On an 8 cylinder, once all together with 32 rings (4 per slug) and bored/honed, takes at least an 18" breaker bar to rotate it at first.
Small wrench to turn it should be fine.
It's already been mentioned in this thread, but here goes again, in these engines (almost all engines for that matter) on the connecting rods and mains, they are always orientated in direction by the bearing retaining tangs always being on the same side of the parting line, if you got a retainer tang on each side, you've got it in wrong.
boxfullofyertoys
boxfullofyertoys
Same here Jack. I think it's my brain just making sure I remember stuff for the next time :smile:
Falkon -
I realized what I had done when I discovered that the edges of the rod caps near the bolts are different (on a stock 1500 anyway). One edge of the cap has a much wider squared lip on it, while the opposite side is more rounded and narrow. 3 of the 4 were oriented with a particular end facing downward at the sump, the other wasn't. I flipped odd one it and sure enough everything started to move.
I've been taking some photos of this whole ordeal, and I'm hoping to augment the directions I've been using with them. They're great, but having photos would have been a massive help...
I've been using these directions:
https://users.wowway.com/~kottage/tech/1500_bearings.html
I'd be happy to combine the photos/instructions for the wiki, if need be...is there a wiki around here...right?
jlaird
Sounds like you are ready to move on to other things.
Of course it should need a small wrench. And if you had new rings and pistons in new cylinders you would need a large wrench.
All sounds fine, seems you have done a good job.
Falkon
Went back over all that stuff and it all checks out so i guess im good.
Thanks guys!
The_architect
Boxfullofyourtoys,
I would be very interested in seeing your photos. If you would want to go to the effort of putting something into the wiki it would be great.
Charlie
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 32
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
M Crank Pulley Removal Austin Healey 12
J General TR Narrow Belt crank pulley Triumph 0
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
