TR6 71 block & crank
Buckshot57
Just discovered my block and crank are trashed. Too much end play, thrusts were in the pan. Any tips on what to look for and where to look. Already checked Craigslist and eBay. Any suppliers that offer short or long blocks.
titanic
I have a block&crank from a later engine and am located in Albany. If you are interested, give me a call in the evening or send a private message with your email address.
Berry (541)926-5710
2wrench Crank's finally, lastly married to the block Triumph 11
2wrench Block pics prior 2 and after offering up the crank Triumph 20
2wrench Good block, good head, check out my crank shot. Triumph 5
Hap Waldrop A series plus block and crank British Motor Corp 2
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
sim A-series Engine Block Search Spridgets 2
T Block Heaters Austin Healey 3
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bremer TR2/3/3A Block deck height? Triumph 10
Bayless Memory block Spridgets 3
D TR2/3/3A Coolant tap on TR3 block Triumph 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
Sarastro TR4/4A Engine block deck flatness Triumph 9
KVH TR4/4A Block Water Outlet Valve Triumph 13
D 3000 engine block Austin Healey 0
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
S BJ7 frozen temperature sensor to block Austin Healey 17
D mystery of the day... pedal block? Austin Healey 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
M TR6 Front sealing block Triumph 11
H Post-War Other Herald rear suspension lower block installation Triumph 3
D Engine Block Austin Healey 14
jfarris TR2/3/3A Head stuck on block Triumph 8
