Block Heaters
twas_brillig
Our BJ7 has an immersion type block heater in it, from the original owner; our Bugeye came with one of the ones that replaces a headbolt. I doubt if anyone drives vehicles like this in the winter anymore (back in the day, our BE was our sole vehicle for one winter), but I also thought that there might be some folks interested in a paper I ran across recently, written in 1972 at the University of Saskatchewan https://library.csbe-scgab.ca/docs/journal/14/14_1_15_ocr.pdf And this is the only automotive type site I sign on to.
Briefly: the authors instrumented up a straight six and a V8. Two hours gives you most of the heating effect; five hours pretty much gets you to the maximum temperature. And the combustion chambers got to the highest temperatures. And the oil in the sump didn't much warm up at all.
It was brass monkey weather here last week (-37C/-35F one morning) and our 2009 BMW X3 didn't want to crank (no block heater) but fired immediately.
I'm assuming that the important aspect of a block heater back in the days of carbs would have been that warm cylinder head, helping the fuel droplets to atomize/vapourise/ignite. But if the water jacket is warming and the oil in the sump is still cold, why does the engine crank better with a block heater? The cylinder walls/piston rings will be warmish; the crank & bearings will be colder than heck; the valve train will be warmish, etc. etc.
Knowledge would be appreciated. Doug
NutmegCT
Depending on the design of the heater ... I'd think an engine would start more easily in winter if the oil in the cylinders were warmer (less friction) than still cold. Cranking would have less resistance if the oil along the piston sides were warmed.
(Despite living in Wisconsin for over ten years ... I have no knowledge of how my block heater actually did its job - just logic.)
For an Ohio winter or two, I added a "block heater" to the sump of my '99 M Rdstr. Cold (stiff) oil was deemed the culprit of its centrifugal supercharger failing, according to Vortech, its manufacturer, and there were times when it was relegated to being parked outside overnight.
I bought a commercially available magnetic block heater, but BMW engines have aluminum sumps, so I found some thermally conductive epoxy and used that to bond a small (postcard sized) piece of steel to the front of the pan. My only objective WAS to preheat the oil, as I otherwise had no issues with cold-weather startup, warmup or setting off driving, I just needed to appease the supercharger!
Michael Oritt
You can get a block heater that inserts in the dipstick tube:
Kat's Crankcase Dipstick Heater 23" 90 Watt​
Being resistive-type heat they are power-hungry.
sim A-series Engine Block Search Spridgets 2
B TR6 71 block & crank Triumph 1
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bremer TR2/3/3A Block deck height? Triumph 10
Bayless Memory block Spridgets 3
D TR2/3/3A Coolant tap on TR3 block Triumph 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
Sarastro TR4/4A Engine block deck flatness Triumph 9
KVH TR4/4A Block Water Outlet Valve Triumph 13
D 3000 engine block Austin Healey 0
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
S BJ7 frozen temperature sensor to block Austin Healey 17
D mystery of the day... pedal block? Austin Healey 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
M TR6 Front sealing block Triumph 11
H Post-War Other Herald rear suspension lower block installation Triumph 3
D Engine Block Austin Healey 14
jfarris TR2/3/3A Head stuck on block Triumph 8
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
J Austin healey block Austin Healey 18
Zitch TR4/4A New fuel pump fitment to block Triumph 3
M About alternator bracket and cylnder block interface on BN1 Austin Healey 9
jfarris TR2/3/3A Stopcock on side of engine block Triumph 3
