TR4/4A Oil drain hole from rear crank seal/rear main cap
TuffTR250
The oil drain hole in the main bearing cap in the TR4 engine in my TR3 is very small and it seems to me that this hole is not large enough to adequately drain the oil from the rear crank seal assembly tossed there by the crankshaft thrower grooves. I have attached a picture showing the very small hole in the tube which acts as the drain. In the picture it is just above the large pipe. Should I drill out this small hole in the rear main bearing cap so the oil would drain out better? Thanks!
Regards,
Bob
TR4nut
Bob-
I wouldn't touch the smaller drain hole. The large tube is actually the main drain there while the engine is running - my guess is the little tube is for draining any small amount of oil out when the car is shut down. A common practice to help drain is to add some larger drain holes - Mark Macy has a good writeup:
https://www.macysgarage.com/myweb6/Rear_seals.htm
I did this on two engines I rebuilt, no problems but not sure it helped much either.
I've also gone to the new design seal by Christian Marx, sold in the use by Joe Alexander, Roadster Factory, etc. Chris has a good writeup of the install of his seal:
https://www.tr4-racing.de/download/splitseal.pdf
I think when Chris first came up with the design, he also showed drilling extra drain holes in the rear cap - but has since eliminated that step. My next rebuild, I'm staying with the new seal design and leaving the cap alone.
TomMull
TR4nut is completely correct. If you look on the other side of that small hole, you will find very little room for enlarging. Tom
J Toyota tranny conversion question, oil drain hole Austin Healey 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
B TR4/4A Oil Drain plug size Triumph 14
J TR2/3/3A Oil drain plug stuck Triumph 10
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
Marla TR4/4A Oil Drain Plug Triumph 4
KVH Leak at Oil Drain Plug Triumph 12
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
L What size and thread pitch oil drain plug? Spridgets 5
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
Stewart Leaky transmission oil drain plug MG 3
RandallRK Differential oil drain plug Austin Healey 13
tahoe healey trans oil drain Austin Healey 11
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
RSMTR8 Wedge TR8 Oil Drain Plug Triumph 1
78MGB Oil Drain Plug Washer *DELETED* *DELETED* MG 3
kindofblue Which Tool for the Oil Drain Bolt? Triumph 9
tahoe healey oil drain plugs Austin Healey 11
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
