How regular should I change the gearbox oil?
BN6_2197
Gents, my gearbox incl. O/D unit was refurbished about 8 years ago. Til know I drove about 6.000 miles. While searching for a problem of the O/D activation I notices that there is "mud" in the oil filter of the O/D unit. Hence I changed the oil. My question is: how often should I change the gearbox oil? I thought that there is no need doing a regular oil change when drivin only a few miles per year.
Cheers,
Volker
bob hughes
Volker
If you have a hand book ( I have an original 100/6 book) it suggests that every 6,000 miles - 10,000 Km you should change the oil, and check it every 1,00 miles - 1.6 Km and top up as required. It would be a bit onerous if it was a daily driver but after 8 years it may well be worth it, I understand that the properties of the oil can deteriorate with time.
:cheers:
Bob
I've used synthetic gear oil--Redline MT-90--for many years and miles. A couple years ago I pulled the gearbox and OD to fix a jumping-out-of-gear problem, and the box was clean and the gears perfect (the oil probably had 15-20K miles with that fill). The gearbox/OD oils don't get polluted by gas and combustion byproducts--or any dirt that gets past the air filters--and modern oils, especially synthetics, are much more resistant to shear and sludge than the waxy old dino oils prevalent when these cars were built (and the manuals written). Put in a good synthetic gear oil, or at least a good modern mineral gear oil and, out of an abundance of caution, leave it in for 10K miles or more (note a synthetic will likely leak a bit more). I use synthetic oil in both my Healeys' gearboxes and differentials, but use a good mineral oil--Valvoline VR1 20W-50--in the engines since our cars sit more than they move (I try to change them at least once/year, though I've been a bit remiss the last couple years).
In many/most/all? modern cars the differential, which experiences greater shear forces but also shouldn't get cruddy, has a 'lifetime' fill; i.e. it's not meant for replacement for the entire life of the car (which could be 200K miles or more).
Michael Oritt
Volker--
Whenever you get around to changing the gearbox oil take a couple of minutes and pour the used oil into another vessel in good sunlight. Seeing all the yellow stuff that had been floating around in suspension may lead you to shorten the change interval. Same goes with the diff oil.
Non-detergent mineral oil was originally specified in the manuals. The theory, at least what I've heard, is that the tiny particles of ground metal will settle to the bottom of the case forming the 'mud,' whereas a modern detergent/dispersant oil would cause the particles to be suspended, as Michael attests. When I do change my gearbox oil, there will be tiny particles--judging by the color they are brass, likely from the shift forks wearing--that are visible in bright sunlight (kinda pretty actually). I was alarmed when I first saw this, but rubbing the oil between fingers I could tell the particles were extremely small, so small you could not feel them at all (note some greases; moly, lithium, etc. consist of finely ground metal thickening an oil). My take is the suspended particles are so small they do no damage--brass is a fairly soft metal--and will not cause any passages to be blocked. I don't know exactly how long I've been running synthetic gear oil in both my boxes, but it would be at least 75K miles, and I've had no problems that could be attributed to using synthetic. As a bonus, a good synthetic gear oil will give noticeably smoother shifts and, since the viscosity is more consistent an OD will engage slightly faster (esp. when hot). There is never any mud when using a proper synthetic oil; note I don't use synthetic oil in my engines, as I change the oil often relative to my daily drivers, and the synthetic will leak a bit more than conventional gear oils. I recently rebuilt my BJ8's box, and paid particular attention to surfaces and gaskets, and used a good sealant on the paper gaskets, and there are no significant leaks once I solved the activating cross shaft O-ring leaks.
C High test or regular gas? Jaguar 4
Healey Nut Silicone or regular Austin Healey 8
T Regular vs stainless steel pistons for calipers Triumph 13
Bruce_B Fluid for MC Brake and Clutch?? Synthetic--REgular Spridgets 4
G Don't use "Metal Ready" prep for regular paint !! Spridgets 13
LuckyLuke Synthetic vs Regular Brake Fluid Austin Healey 3
10musketeer Lucas Fuse vs. Regular Spridgets 3
Musicman Oil - Regular vs. Synthetic Triumph 19
Musicman Fuel - Regular or Unleaded Triumph 25
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
