Hi, I hope this answer helps.. I put the Konis on around July of this year. I have poly bushings, sway bay, revived camber, etc, I set mine at IIRC one click stiffer. They worked well, but it was apparent then rear shocks heeded help. I had 30wt Redlin shock oil in them. It was way to stiff. I replaced it with 10 Wt Redline oil and the car balances well. My rear shocks are original as far as I know. The key here is once you like the front end, look at tuning the rears.
RG
