MGB Wiring problem....this should be fun :[
Joe Reed
Well, I installed my new horns, reinstalled the grill and bumper.......then decided I should check the lights. They worked properly before. Not now. Obviously I disturbed something (or some things) while playing around under the slam panel.
Now when the parking lights are switched on:
-RF parking lamp is bright, LF parking lamp is dim.
-LR is fine, but RR both the turn signal lamp and the brake lamp are lit.
With the headlamps on everything is the same as above - except that the LF headlamp is also dim (RF is fine). Turn signals don't work.
With the lights off, the turn signals work - but the right side is dim (both F & R)
Hazards work fine.
Looks like I'll be pulling the bumper and grille off again to recheck all the connections - especially any grounds. Shoulda checked then before I reinstalled those (although it's only a few minutes to yank them off)...
Mickey Richaud
My money's on ground connections.
Joe Reed
Joe Reed
Yeah...that's the most likely. It's easy to disturb old wiring and connections when you've got limited access to the area.
Joe Reed
Joe Reed
Well that was quick and easy! Didn't even have to break out the old multimeter :smile: First thing found was an unplugged ground wire on the left side. That fixed the dim headlamp and parking lamp on that side. Second was a suspect connection at the right front parking lamp. Fixed that and now everything works perfectly!
It always amazes me how a bad connection on one end of the car can create havoc at the lamps on the other end :smile:
P TR6 Wiring problem Triumph 50
C TR6 Wiring problem Triumph 3
Tinkerman TR2/3/3A TR3A Horn Wiring Problem Triumph 2
jaegzie Ignition/Wiring problem. Spridgets 11
R Under dash wiring problem-BJ7 Austin Healey 10
R BJ-7 Fuse block wiring problem Austin Healey 18
R BJ-7 overdrive relay wiring problem Austin Healey 1
Shealey Getting close with the wiring Just one problem Spridgets 4
Jayrz Wiring problem Spridgets 5
VelodromeRacer Possible wiring problem? Austin Healey 3
R Solenoid Wiring Problem Austin Healey 12
M Spitfire Spitfire[Lucas]wiring problem FOUND! Triumph 12
J another lucas wiring problem Triumph 7
D TR6 Wiring problem - re headlights/starter motor 74TR6 Triumph 6
bluemiata90 TR4/4A Wiring problem with TR4 Triumph 8
Obtong Horn Wiring Problem MG 9
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
