Wiring problem
Jayrz
So yeah, no power to the headlight wires out in the nose and, no power to the dimmer switch down in the footwell.
Anyone have any ideas where to start this journey.
And, car is a GAN1 Midget, 61 or 62
Thanks guys
Jay
jlaird
Yep, at the switch on the dash.
spritenut
Check for power at the switch (brown is always hot, blue goes to the headlamps) If you connect the brn to blue the lights should work. If not, suspect the dip switch, it has 3 wires, blue is hot going in (center terminal) connect the blue to either other wire, low or highs should come on. If not, check the dip harness where it meets the headlight harness sort of near the coil, look for 3 wires blue, blu/red, blu/white.
Clean those connections and make sure the ground is clean and connected at the inner right fender sort of behind the heater hose clamp, that is the headlamp ground.
Jayrz
Jayrz
Ah Hah!
Problem was the dimmer switch on the floor... power going in and nothing coming out. I replaced it with a known good one I got from Sports car Craftsman here in Denver and replaced both headlight pigtails and wa-la,, I have headlights.
And since I was on a roll i replaced the flasher unit and hooke up the new turnsignal switch,,, ta-da, I now have turn signals too.
I know it sounds like I am way too excited about this but my only electrical problem left is the brake lights and then they are all fixed!
jlaird
And that is prob grounds or the switch its self.
P TR6 Wiring problem Triumph 50
C TR6 Wiring problem Triumph 3
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
Tinkerman TR2/3/3A TR3A Horn Wiring Problem Triumph 2
jaegzie Ignition/Wiring problem. Spridgets 11
R Under dash wiring problem-BJ7 Austin Healey 10
R BJ-7 Fuse block wiring problem Austin Healey 18
R BJ-7 overdrive relay wiring problem Austin Healey 1
Shealey Getting close with the wiring Just one problem Spridgets 4
VelodromeRacer Possible wiring problem? Austin Healey 3
R Solenoid Wiring Problem Austin Healey 12
M Spitfire Spitfire[Lucas]wiring problem FOUND! Triumph 12
J another lucas wiring problem Triumph 7
D TR6 Wiring problem - re headlights/starter motor 74TR6 Triumph 6
bluemiata90 TR4/4A Wiring problem with TR4 Triumph 8
Obtong Horn Wiring Problem MG 9
T TR6 Alternator wiring Triumph 6
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
