TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not
rnpennington
I just spent 2 hours doing a 15 minute job (OK not unusual for me), but I 'm sure there must be a better way.
I noticed the screw holding the outside door handle was loose, so I took the handles and door card off so I could get to the screw - this time with Loctite.
However, the other hour and 45 minutes were devoted to getting the inside door and window handles back on. I'm sure there is an easier way to do this.
First, is the large end of the spring securing the black plastic supposed to be inside the door? That's the way it was when I took it out, but seeing the design of the plastic, it made me think that maybe part of the spring is supposed to be inside that plastic. However, I left it the way I found it. I then pressed the handle and black plastic in, using a hole punch to line up the hole in the handles with the hole in the door and window protrusions. I then pressed them from the other side to insert the pin and force it through. Only took about 20 minutes for the window handle, but the door handle was another story. I finally took a bolt cutter, cut off part of the spring and then it only took another 20 minutes.
Again, it sounds easy but it is a PITA (and not the bread).
Surely there is an easier way, so I'm looking for advice for when I have to do this again!
bobhustead
My experience is very old (see humor section of forum on expansion of past), but I think the spring thingies go in the handles, which you then push onto the tapered ends of the operator, expanding the springs until they drop into the groove.
Bob
R
rnpennington
I always liked the phrase "Experience may be the best teacher, but I can no longer afford the tuition"
Spring goes under the panel, compress black ring back enough to push pin it. I have found the easiest way to install pin is use a clothes hanger, straighten the rod,insert the rod into handle to mark the length, score each side at that mark. Compress black ring, install handle, the scored long rod should slid in, then snap the long rod off. That should do it
marv
R
rnpennington
I have come to the conclusion that Triumph had a group of 3 handed people whose job it was to do this. I needed to use both hands, (one on each side of the black plastic to fully compress the spring). and a third one to insert the pin Because of this when they ran out of 3 handed people, they had to shut down the factory.
Trevor Jessie replacing window rubber and felt in door Spridgets 6
Gerald_Gordon TR4/4A Hard door closing after replacing rubber seals Triumph 8
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
P Replacing door hinges and paint British Motor Corp 4
B TR6 replacing U joints Triumph 3
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
