How often should you change the rear rear axle oil
bob hughes
I have had my car since 2002, I have checked and topped up the rear axle oil on several occasions, but I have never changed it. Having completed an oil change to the engine and gear box, the thought occurred to me that at some point I should possibly change the oil in the back axle. I went on a search through the Hand Book and the Workshop Manual and unless I have missed something, I could not find anything definitive.
Any Ideas?
:cheers:
Bob
Michael Oritt
Change it every 15 years or 15,000 miles..
number6
A few years ago I went to change the Spitfires rear end oil only to find no drain plug. I don't think anyone I have talked to has any definitive answer to the question if the owners manual does not.
My feeling is topping off is probably all that's needed. The rear end is not seeing the byproducts of combustion the engine sees.
B
bob hughes
All true, but having changed the gear box oil, there is a definite breaking down of viscosity with time and use, though the oil was clean as a whistle. Using Michael's suggestion, I had better consider changing because 15 years is now up and I passed 6,000 yonks ago. :glee:
:cheers:
Bob
Did you know what was in the axle when you topped it up? If you didn't, you might have mixed viscosities, which isn't a good thing.
Since you've never changed it, it would be a good idea to do so. Modern cars only recommend a change every 100-150K miles, and they make it difficult as the manufacturers don't put a drain plug in the diff housing. Put fresh oil in--I like synthetics here--and never worry about it again.
Michael Oritt
Bob--
Though my first response was said tongue in cheek I do think that diffs and transmissions often deserve better lubricant care than they get, and if anyone thinks these do not need draining/refilling, remove the drain plug, collect and examine the oils under bright sunlight and you will see a rainbow of metallic particles. Though shedding of fine metal is normal the point is that wear does take place and getting this stuff out of the equation can only add life to your gearbox or rear-end.
On my Healey, which currently sees no more than 5-6K miles per year, I still change both transmission and diff oils (Redline MTL and MobilOne synthetics) at least annually. And I change transmission and differential lubricants on my race cars every other race weekend as they see extreme use and the consequences of damaging either is costly both in terms of replacement and money/time lost to a DNF.
... On my Healey, which currently sees no more than 5-6K miles per year, I still change both transmission and diff oils (Redline MTL and MobilOne synthetics) at least annually. And I change transmission and differential lubricants on my race cars every other session as they see extreme use and the consequences of damaging either is costly both in terms of replacement and money/time lost to a DNF.
Can't go wrong with that schedule, but I've generally changed my gearbox oil every 15-20K miles and the diff oil every 40-50K and never had any problems (IIRC, Norman Nock said to change gearbox fluid at 15K miles, and he was 'old school'). By 'never worry about it again' I presumed typical LBC owners don't put more than a couple thousand miles a year on their cars, so 20 years or so (how many of us gonna last that long?). My Mustang's scheduled diff oil change is at 150K miles, so the manufacturers think they aren't needed all that often (and it's a revenue stream for the dealers). The Mustang has a live axle and uses diff fluid to lubricate the rear bearings, just like a Healey.
RAC68
Hi Bob,
Rear end gear oil should be changed whenever you change a part in the rear or axels (seals or components). Other then those events, I would expect the gear oil or synthetics to be just fine. Although changing the oil in the rear will not heart, since there is no source for continuous contamination as with the engine, I see no reason the rear oil would deteriorate and loose its lubricity. However, regular checking is critical to make sure the oil is up to level.
Keep in mind that the Mustang's schedule of 150K miles is, on a Healey, tantamount to never change.
Ray(64BJ8P1)
Hi Bob,
Ray(64BJ8P1)
Agree on all points, Ray (that's why I said 'never worry about it again'). But, if you have to dump the fluid, might as well put fresh in.
Side note: Looks like I'll be pulling the gearbox/OD on my BJ8, and draining the fluid. Since I just put almost 4qts of Redline's finest in--that's about $80--I'm debating trying to filter and save the fluid, and put it back in. Otherwise, a massive waste.
RAC68
I have always tried to find an approach that allows for the least expensive highest quality solution to any Healey issue I encounter so, in this case, I would seriously consider filtering the fluid for re-use. That is, unless I had a failure that could have expelled a massive amount of small bits into the fluid...or even the potential of that happening. If I was concerned the fluid was compromised beyond filtration in any way, then spending the additional $80 is a cheap price for piece of mind.
Ray(64BJ8P1)
58Custom How often should carb damper oil need topping up? Spridgets 4
Gliderman8 TR6 Valve clearance- How often do you set them? Triumph 4
JPSmit How often do you change your spark plugs? Spridgets 7
M How often to check/adjust valves? Triumph 7
K TR2/3/3A TR3 SU dampers again....how often to top up? Triumph 5
D How often must I check the Triumph1500 Thrustwashr Racing 1
G Don't come in here often MG 13
Brit_Brother How often do you check your SU fuel pumps ? Austin Healey 25
7 How often do you change... [on a modern car] Restoration & Tools 8
prb51 How often do 'You' regrease the front bearings Triumph 5
78MGB Waxoyl: How often??? MG 3
J how often do you drive your car this time of year? Austin Healey 7
G So, why don't I post more often??? Jaguar 4
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
