TR2/3/3A I have a doubt about the gearbox
vype
Hello everyone,
The restoration of my TR3A continues slowly but surely. The chassis will soon be on its wheels again.
I start to take care of the gearbox in parallel. It is a gearbox without OD.
I did not intend to open it but after cleaning and inspection I noticed that the input shaft had a radial clearance of about ~0.12" measured at its end.
Do you think this is OK or do I have to disassemble and change the bearing (s)?
Graham H
My guess is that it will be ok once you fit the box back in the bush in the end of the crankshaft will take up any slight movement in the input shaft.
Graham
TR3driver
Great Pumpkin - R.I.P
Doesn't seem like a problem to me.
But I would still open it far enough to do some inspection, including pulling the countershaft out far enough to check the bearing surface under 1st gear. It's a known weak spot, and a whole lot easier to deal with now, than after you've put it back in the car and the car together around it. Use a dummy shaft to hold the bearings & gears in place.
CJD
+1. I would not rebuild for that little play on a known tranny, but these are not strong gearboxes. As a minimum I would pull it for new synchro rings, top hat bearing, countershaft bearings, mainshaft C clip, and seals. Of course, all bearings are a good idea, and even a working tranny may have minor broken parts inside.
V
vype
Thank you all for your feedback and advice.
I am reassured but I will follow your advice and push my inspection a little more while the box is out of the car.
DavidApp
It is better to get it fixed while it is out of the car. My transmission seemed OK but when I started driving I found it would jump out of second gear on deceleration. Worked fine except for that small issue.
I found an OD transmission and had it rebuilt.
David
V
vype
Good morning all,
After investigations I found the origin of the play of the input shaft. I thought it came from the bearing but in fact it is the internal bronze bush which is very worn (~0.02")
(part 10 on the Moss catalog).
So I decide to dismantle the whole gearbox to check and redo it.
The bush was replaced by a bearing on the more recent boxes and I wonder if I could not replace it by a bearing on mine. I do not know if the diameters
correspond and if the lubrication groove of the axis will not be a problem because the bearing does not have an inner ring.
What do you think about this?
CJD
You were right the first time. Play in the input shaft is from the large bearing. The pilot bearing, in the tail of the crank supports the nose of the input shaft and keeps the clutch disk aligned. A bush is best for this bearing unless you like to launch at 5k rpm.
The other “bush” i think you are talking about is inside the tail of the input shaft and keeps the mainshaft aligned to the input shaft. That one was later changed to a roller bearing. To switched to a roller bearing you would need a new input shaft and mainshaft. I recommend keeping the bushing, as that is not a normal failure point.
TR3driver
I'm with John, I don't think that bushing (or the later roller bearing) is supposed to be so tight to the mainshaft that it will keep the input shaft from tipping. IMO what you are seeing is the accumulated clearance in the big ball bearing that holds the input shaft to the housing. Remember, that little bearing spins pretty fast, and carries a lot of load when in 1st gear. So it can't be super tight. And any movement at the bushing will be amplified at the tip of the shaft, because it's so close to the ball bearing.
IIRC, Bob Schaller (RIP) actually recommended retrofitting a brass bush to the later gearboxes, because of problems with the roller bearing.
.020" is worn, certainly and I would replace it. But not worth trying to re-engineer the joint.
Interesting, if not necessarily relevant: According to the SPC, the factory first tried the roller bearing at TS26825 (with a corresponding change to both input shaft and mainshaft); then went back to the bushing for 11 gearboxes before doing a second change to rollers at TS27063, with yet another input shaft, mainshaft and bearing. Make of that what you will, but my take is that the first change failed in some way, and they had to go back to the old setup while they re-engineered the change.
If you do want to convert to rollers, I think you need to find the later shafts that are machined and hardened with rollers in mind. The rollers are surprisingly picky about the surfaces they run on, and getting it wrong will lead to rapid failure. The input shaft could probably be machined to accept the even later bearings that come with their own outer race, but you would still need an inner race surface, not your existing mainshaft.
V
vype
Thank you very much for your feedback.You are right. I will change the 3 bearings of the main shaft and replace the ring in the input shaft with a new one and forget the idea of ​​replacing it with a bearing.
John your thread about the gearbox rebuild is very interesting.
It is true that it is not always obvious to know if a part is to be replaced or not and your explanations are very useful.
L Without Doubt Triumph 15
G When in doubt, read the instructions.... Triumph 3
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
R Gearbox and Overdrive Oil Level Austin Healey 18
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
