Need info on gearbox and rear end oil for midget
chad
Hello everyone,
I could use some help. I need some advice on what grade of oil goes in the transmission and rear end of my 65' Midget? It has the 1098 motor. I'm about to get the car going for the first time, and wasn't sure if about these fluids. I did see some gearbox oil on the moss motors site, but wasn't sure, thanks
20W50 Motor oil in the transmission
Gear oil in the rear diff.
scoutll
Transmission takes engine oil 10-40 or 20-50 is recommended. Most places jusst say use the same stuff in the tranny that you use in the engine. I use 20-50 in mine. The rear end takes GL-4 gear oil, 90 wt for summer and 80 wt for winter if you change. Some people say they use GL-5 in the rear end, but I have also heard and read a lot of people who do not recommend it in older cars... I have old GL-4 around, so use it.
*edit*
I see Trevor already answered while I was slooooooooly typing.
Yes ... but I'm always light on details.
scoutll
You always get your point across :thumbsup:
JimLaney I need some basic restoration info for my first car project Restoration & Tools 20
H T-Series Need carb linkage info for my TD MG 1
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
Gliderman8 TR6 Need battery info please for TR6 Triumph 4
drambuie Need info for Elkhart lake event this summer. Austin Healey 10
I TR6 Need help on 69 TR6 glove box info Triumph 0
S Need to know where to find info MG 1
RickB Need info about Miata seats in Spridget Spridgets 49
toysrrus TR2/3/3A TR3 M/C Blanking Plate: Need some info. Triumph 2
D Overdrive basics - need info Triumph 11
B Need info again- Other British Cars 1
B --NEED YOUR HELP/INFO NOW!!!!!!- Other British Cars 0
B --NEED YOUR HELP/INFO NOW!!!!!!- MG 2
G Need info on powder coat equipment and books Spridgets 5
G Need info on Rover K / 4AGE swap Spridgets 29
S Need info and gasket for a stromburg. Triumph 9
C Need Info on air intake flange for midget mkII 65' Spridgets 5
toysrrus "Need Info" on "New" Spridget VIN & Engine No`s: Spridgets 45
R Need paint info/ assistance Triumph 13
J Help, I need some BT7 trans info Austin Healey 3
69sprite Back to work, need some bolt info Spridgets 6
LastDeadLast Need some info - Harmonic Damper Triumph 14
R Need 185/70/15 Tire Info Austin Healey 12
YankeeTR TR2/3/3A I need some info on broken TR2 Lockheed axles..... Triumph 0
C Need info on Whitworth hardware Restoration & Tools 3
bcliff New Owner, need info, parts, and everything! British Motor Corp 5
TR_JOE250 TR5/TR250 Need info for fitting triple ZS carbs to TR-250 Triumph 7
jlaird Need some info on a Bugeye Spridgets 9
bcliff Post-War Other Need Spitfire/Herald info Triumph 2
Beavis GT6 GT6+ electric vehicle project. Need Info/Advice. Triumph 13
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
