Need info about Miata seats in Spridget
RickB
Anyone who has done this or knows about it -
Are there specific years of donor cars I should look for, do all work or just some?
What are the issues, I know about the tonneau not fitting the headrest - anything else?
Gerard
Rick,
I've done a couple, but on chrome bumper cars. I don't think the original mounting holes are different in a rubber bumper car, but I'm not positive, so my remarks are in context of a chrome bumper car. YMMV
There are a couple ways to do it depending on how much fuss you want to make. I went to the trouble of making some custom brackets so that no modifications were necessary to the seat rails or to the floorboards.
The stock Miata rails can be bolted to the original rear floorboard holes (they line up pretty much the same). The front ones will be farther forward, so you'll need to make new holes. The Miata seats also have locating pins at the front, which are fairly long and so you will want to cut them off. The front of the brackets are angled slightly, so you will want to straighten them a bit. The holes in the seat rails (front and rear) are rather large, so you'll need some fender washers and maybe a stack of washers or some spacer material to get everything level.
You can see how mine look in this slideshow link for my '68.
https://www.vuvox.com/collage_express/collage.swf?collageID=0134319034
Gerard
RickB
RickB
That looks very nice, your car is a very fine example!
The seats look great in there too.
Thanks for the help.
taskadog
I mounted mine directly to the floof. i got some #11 IIRC all thread and put about 3" studs into the bottom of the Miata seat. Drilled two new forward holes and bolted it down.
My factory tonneau works great.
Phil
twas_brillig
Gerard
There is just as much room in a Bugeye, but (in my opinion) high back seats don't look right in a Bugeye.
Gerard
jlaird
Actually think about this. The thicker the seat back the less leg room you will have.
No prob if you are a little person but.....................
Jim_Gruber
I mounted Miata Seats in Bugsy my '68 Sprite. I cot off the fornt locating pegs and was able to match up inside front hole on both sides. I used a 1" piece of square bar stcok under rear of the seat track to raise it up and keep the seat move level. It is possible to use adapter plates and not need to drill any new holes. I have a Rollbar in Bugsy and seatback recline is a little limited but I have far more room than stock Square Bodied Spridget seats with headrests. And the speakers in the headrests. Is is actually possible to hear the radio at speed.
Would I put them in a BE, well seats are supportive., I've got a Spridget with a BE Front end and I think they look awesome. Without the rollbar and windblocker, hmmmn... Beauty is in the eye of the beholder.
Jer
That's the problem with the Spitfire seats in my 67' Midget, they don't fit back as far as the original seats & even with my stubby legs (27" inseam) I can't stretch my leg out, as soon as I can find some original seats (65 - 68) I will be yanking those Spitfire seats ! Never appreciated the difference until I got my 74 with original seats this past fall, only other midget I have ever sat in.
jlaird
So, think about this. BE seats are only about 1/3 as thick as other Spridget seats.
Every couple of inchs is a joy.
RickB
RickB
My son and I went to a couple Salvage yards yesterday that said on the phone they had Miata's.
The first had one car, it had seats in it however no top over the car and the seats were leather. The seats were in terrible condition, the drivers side was torn pretty badly.
I went next door to the other yard (competing business) and looked at their Miata.
It had the top covering the seats so I looked them over and pretty much liked what I saw.
I went to the counter and asked how much they wanted, it was $200 for the pair.
I told them the speakers had already been pulled from the headrests and the drivers side was worn and offered $100 for the pair. The guy said that's good so I went out and pulled them.
Of course the convertibles are stored on top of the sedans so it was a reach getting the bolts out. The very last bolt was a bugger (of course).
I ended up getting in the car in the space the passenger seat had formerly occupied in order to get enough traction on the wrench to get the bolt to budge.
Then I carried both seats and my tools - of course the Miata was as far away as it could possibly be. I even called the office from out there to ask if they had any sort of cart to haul big stuff back - they didn't.
The seats are good, I have to clean them up and then see how I can put the passenger in as the driver and vice-versa.
The wiring is intact so I can put new speakers in once I figure out what to buy.
No seat heaters, but I actually have a nice pair of seats for $100.
Maybe one of the big lbc vendors still has a seat heater kit on sale...
Oh - they are black, so I may be dying my interior black to match.
A green Midget looks good with a brown, or tan or black interior.
I don't think mixing black seats and brown interior is appealing though.
Jim_Gruber
Congrats on the seat. You will love them. I'll be happyt ogive better description if needed on what I did to make them fit in Bugsy.
twas_brillig
Dang! I'm jealous (both over the seats and the nearly free price). Check with the aftermarket folks as there are speakers for the DIY'er that wants to install speakers in his seat headrests; presumably they'll have them designed to replace the original Miata as well.
Doug
Jim_Gruber
Congrats on the seat. You will love them. I'll be happy to give better description if needed on what I did to make them fit in Bugsy.
RickB
RickB
Thanks Jim, I'd love to get more info before I start fitting them!
RickB
RickB
Before I buy speakers I'm looking at a set of seat heaters.
It's cold out there!!
Jim_Gruber
You'll need an alternator ifrst and foremost.
RickB
RickB
Remember, I have the Datsun A15 and 5 speed 60L combo in my car.
So yeah - I've got an alternator...
:jester:
RickB
RickB
Wow, new seat covers for the Miata seats cost a LOT less than Spridget coverings.
There are sellers with vinyl covers for $100 - $150 and leather for around $250 and up.
Compared to Spridgets at $300 and up for vinyl and sky high for leather.
Wow!
Jim_Gruber
Lots more Miata's out there now and there is competition not limited sources of supply. The Free Market System at work.
JimLaney I need some basic restoration info for my first car project Restoration & Tools 20
H T-Series Need carb linkage info for my TD MG 1
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
Gliderman8 TR6 Need battery info please for TR6 Triumph 4
drambuie Need info for Elkhart lake event this summer. Austin Healey 10
I TR6 Need help on 69 TR6 glove box info Triumph 0
S Need to know where to find info MG 1
toysrrus TR2/3/3A TR3 M/C Blanking Plate: Need some info. Triumph 2
D Overdrive basics - need info Triumph 11
B Need info again- Other British Cars 1
B --NEED YOUR HELP/INFO NOW!!!!!!- Other British Cars 0
B --NEED YOUR HELP/INFO NOW!!!!!!- MG 2
G Need info on powder coat equipment and books Spridgets 5
G Need info on Rover K / 4AGE swap Spridgets 29
S Need info and gasket for a stromburg. Triumph 9
C Need info on gearbox and rear end oil for midget Spridgets 5
C Need Info on air intake flange for midget mkII 65' Spridgets 5
toysrrus "Need Info" on "New" Spridget VIN & Engine No`s: Spridgets 45
R Need paint info/ assistance Triumph 13
J Help, I need some BT7 trans info Austin Healey 3
69sprite Back to work, need some bolt info Spridgets 6
LastDeadLast Need some info - Harmonic Damper Triumph 14
R Need 185/70/15 Tire Info Austin Healey 12
YankeeTR TR2/3/3A I need some info on broken TR2 Lockheed axles..... Triumph 0
C Need info on Whitworth hardware Restoration & Tools 3
bcliff New Owner, need info, parts, and everything! British Motor Corp 5
TR_JOE250 TR5/TR250 Need info for fitting triple ZS carbs to TR-250 Triumph 7
jlaird Need some info on a Bugeye Spridgets 9
bcliff Post-War Other Need Spitfire/Herald info Triumph 2
Beavis GT6 GT6+ electric vehicle project. Need Info/Advice. Triumph 13
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
