I need some basic restoration info for my first car project
JimLaney
I bought two sprites in pieces. Both are MK IIIs. One was to be the basis of a rebuild and the other a parts car. The problem is that the rebuild started and ended very early in the process 15 years ago and I have boxes of parts from several sources including a 948 engine in pieces. The body has been well repaired and the front and rear suspension and axels installed but all the parts are sporting a patina of rust.
Unsure exactly how to proceed I have begun an inventory using several books on spridgets to identify major system components. I have also begun sorting the many small containers of nuts and bolts into sizes and thread type. In order to proceed I need some basic restoration/rebuild information:
1. What is the best method to clean starter motor, generator and other parts that may contain electrical components while requiring removal of grime and rust?
2. I have a new HF blast cabinet and 50 lbs of 70 grit Aluminum oxide. What parts can I safely use the blast cabinet on without risking stopping up tiny orifices ?
3. Should I remove all the suspension parts assembled 15 years ago, clean them of rust and reassemble? Should I expect the seals that were replaced in the brake calipers and the master cylinder to need replacement since they have never been wet with fluid?
4. I have a 1098 engine block reassembled to include crank, bearings, rods & pistons, front and back plate. I was told that the block and the head had been "surfaced". Must I tear the whole thing back down even though the crank, rods and pistons seem to move smoothly?
5. The head has been protected with tape on the mating surface. The rocker arm assembly was assembled incorrectly and does not want to release the pedestals from the shaft where there appears to surface rust. Must I replace the whole rocker assembly?
6. Should I fit everything together and then remove it again to paint the body a final color or can I finish the body and then begin the re-installation of sub systems?
Your experienced advice would be very helpful to a novice.
NutmegCT
Jim - first step - start asking your questions one at a time over in the Sprite forum here:
https://www.britishcarforum.com/bcf/forumdisplay.php?31-Spridgets
There's a lot of help available, so take it one step at a time. What experience do you have in rebuilding cars?
Buying cars in pieces can lead to buying boxes of aspirin.
Hang in there.
Tom M.
JPSmit
Welcome! Glad you are here, you are in the right spot. I have a Vauxhall I bought the same way, and, while it is like a puzzle without a box, it is fun too - and, a Sprite is easy to start with! In terms of cataloguing - Classic Motorsports Mag recommends putting the parts in boxes but, taking a picture before you close the box - then print the pics and keep a catalogue - so, you have the number on the box - with corresponding pic - to know what is actually inside. Of course I have ignored this advice and have parts spread out everywhere! :grin:
Good call! Good books are important - Bentley and Haynes especially. The other thing is Google and Ebay. My Vauxhall is comparatively more rare so, if one comes up for sale, I download the pictures. You should be able to find pics of mist subsystems, or we are happy to provide pics. BTW a few years ago, Classic Motorsport Magazine restored a Sprite - I have most of their articles in pdf so, PM me your email and I can send you them.
Youtube is your friend here - they are pretty easy to dismantle, clean and reassemble - and, even replace the bushes.
Your grit might <might> be a bit aggressive for this use - others can weigh in. I use glass grit. You earlier said patina - patina is different than deep rust - I would still fix it but, you might not need to be quite so aggressive. Products like WD40 will provide enough of a protection till you decide. Also, some of this has to do with whether you want a driver or a show car.
It depends, you should be able to assess many of the parts in place and make a decision - it might be a light sand "in situ" and some rattle can paint is all you need. I wouldn't worry about things like the master cylinder until you have evidence that they aren't working.
Again, it depends, if everything is turning smoothly, you are likely OK - In terms of the block & head being "surfaced" your biggest issue will therefore be the pushrods and whether they have been adjusted accordingly. Also, it is not hard to take down the block - measure tolerances with plastigauge - re-lube and reassemble - with the added bonus of being able to say "I did that too."
It isn't hard to take apart and reassemble the rocker arm
I would suggest that you assemble subsystems and then assemble the car - so, engine first, brakes all done and in a box, wiring, suspension etc. etc. In terms of paint first or last - again, what you want to end up with (show car would typically assemble and then take apart and paint) - most of us have drivers so, paint then assemble.
We were all novices once - there are no dumb questions and this is a very very friendly and helpful forum - I couldn't have restored mine without the help of this crowd!
PS you can't take enough pictures! - don't ask me how I know. And, as Tom says, get over to the Spridget forum - this is for more generic questions like glue and paint and tools. :cheers:
Bayless
JP gave such excellent advice that I can't right off think of anything to add. But Welcome to the forum. This is the friendliest, most helpful car place in the whole world. I bought a Sprite in the same condition. Body is really pretty good but everything else is in a couple dozen boxes. Oh one thing I can add is take lots of photos as you go.
JimLaney
JimLaney
thanks to all who have replied. I appreciate your suggestions and advice.
In answer to the question of show car or driver, I'm definitely planning a driver.
I live in North Alabama outside of Huntsville and near Guntersville Lake. Looking forward to driving back mountain roads around the big lake.
Thanks again for your help.
I will continue to update my blog here as I work on this project.
DavidApp
What size compressor do you have? Blasting can be hard on a smaller compressor. Small jobs are probable OK but larger jobs can really heat up a compressor.
David
JimLaney
JimLaney
David,
I'm lucky and have three compressors - two of them can provide air pressure to the blast cabinet. Newest one is 60 gal tank and provides 9.5 cfm at 90 lbs. I drive stone carving chisels and die grinders with it so I think it will work with the blast cabinet if I use it in moderation. I have another that is larger and it needs some work but it is a 13 cfm at 90 lbs continuous. The smallest one I use to run nailers but it won't power the blast cabinet.
I bought aluminum oxide for the blaster but wonder if I should use glass beads on parts. I thought aluminum oxide would work best on rust but I don't have any experience except cleaning up bronze castings. I also worry about getting the alum oxide in places that will be hard to clean out. Any guidance on media to use on the parts?
Brinkerhoff
Most of the blasting I do is outside with a small ( holds 80lb. of sand) pressure blaster that I've had for 25 years. I use a fine grit silica sand as I find the medium grit leaves too coarse of a finish on steel. You'll need like 60 psi at the blaster nozzle to remove rust. Dial your sand feed down to increase velocity and conserve sand. I would practice blasting on suspension parts first to get the idea of what you are doing. Its easy to ruin exterior sheet metal with any type of blasting if you are a novice, so stay away. I'll do everything except aluminum parts or small ( fit in hand) steel parts with the pressure blaster. I use my cabinet with glass beads for aluminum parts. Blow everything off with clean , filtered compressed air ( a must) , or you will be blowing oils onto your parts which will cause finish problems. I like to use Cyclo Non Chlorinated Brake parts cleaner ( non petroleum based) to clean small parts , then blow dry . Always handle freshly blasted parts with clean gloves.
DavidApp
Where do you get the sand?
I have been getting the Black Diamond medium from Northern tools but if I blast the tub outside I am afraid that I will go through a lot of medium getting the job done. I try to recycle as much as possible. Blue tarps may catch some of it to sieve and reuse.
David
DavidApp
Thank you. Do you use a good respirator while using the sand? I have seen somewhere there are issues with silica sand. I suppose no dust is good for you.
JPSmit
Brinkerhoff
I use a Survivair respirator with replaceable charcoal cartridges and particle pre-filters for sand blasting as well as painting. I'm paying $10 for a 80lb bag of silica sand. As long as you are breathing filtered ( or using a supplied air respirator) air and doing your heavy blasting outdoors with good ventilation , shouldn't be a problem . I won't hesitate to sand blast.
DavidApp
Hello JP
Thanks for the link. Interesting reading. Reinforces what I had heard elsewhere. Northern Tool has glass and slag grit.
David
JPSmit
Hello JP
David
and I find glass gives a nice finish - slag works too but man is it dirty!
JimLaney
JimLaney
Based on the exchanges here, I'm going to switch to glass beads as a media. I'm familiar with media blasting of cast bronze pieces but i thought that the finish would vary considerably based on the media used. I think I can use the Alumn Oxide on seat frames, top braces, and wheels.
Wheels is the subject of my next question. I have 5 matching wheels that I need to put tires on but I want to clean them and refinish them before I mount tires. What processes and finishes do you use to refinish wheels?
I think that I need to clean and media blast the wheels; then seal them with something (primer?) and then paint them or powder coat them. What do you recommend to refinish wheels?
JPSmit
I think the answer is (as usual) it depends. I have rostyles on Ms Triss and media blasted them and painted them with rattle cans. The finish has held up fine and I am very very happy with the results. If you want a higher or harder standard, there is two-pack paint at a shop or powder coating or chrome. I have a friend who wanted to powder coat rims (kei car not MG) and was told that because they rims were two parts and might flex that powder coat wouldn't work - so, not sure what to conclude from that.
I will say that in my general experience, we sometimes get a little to serious about these cars. Wheels are kind of the jewellry of the car so, have fun, white walls, red, white, you name it - they are easy enough to change. For instance, my rostyles are supposed to be black and silver - mine are a cast grey and silver - it is subtle but I think updates it and, to my eyes many rattle can gloss blacks look amateur compared to the factory finish.
Don't overthink these cars - especially Spridgets - don't ask me how I know. :grin:
JimLaney
JimLaney
Thanks. I've read and enjoyed your post describing the refinishing of the rostyles. I think I will clean, blast and rattle can paint the steel (slotted) rims I have since I can do something different later if it is needed. I'm working on a driver rather than a concours restoration so "does it work?" is the question for me right now.
JPSmit
Good question - and good answer. A part of me still wishes I had done a few more things to Ms Triss ( 5 speed/ dual carbs etc) but then I remember it is driving and I am having fun. It seemed like each "good idea" was going to be another $1000 and six more months - so, every time I start thinking about those addons even now I bang my head in a door till the feeling goes away. :cheers:
DavidApp
Hello Jim
I have just done the wheels. Took a bit of work to come up with 5 straight true wheels but I now have a great set and several that have some run out.
I sandblasted them goung through several colour changes on the wheels. Then primed with 2 part primer EURO Classic DTM primer. I had that on hand for the bodywork.
Then painted with rattle can Ford Argent Silver. As I am going out of town for a few weeks I will wait till I am back to get tires mounted. It will give the paint time to harden up.
Looked into powder coating but at between $100.00 to $115.00 per wheel I thought T could get by with rattle can paint.
wheels sand bladsted close up.jpgwheels sand bladsted close up of pat no.jpgwheels painted.jpg
David
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
