Storing nuts and bolts (so you can find what you need)
twas_brillig
We've got German and British 'classic' (i.e. old) vehicles (and a Japanese and a US motorcycle (Buell!). How do you folks sort/store/keep track of nuts and bolts for the various diameters and threads? and materials (mild steel, stainless, and some aluminum)? My brother (now a retired auto mechanic) used 1 litre engine oil containers, cut open and labelled. If I'd been smart, I would've started emulating him decades ago.
I was trying to find some Fine Imperial this evening, and that brought the question to mind.
Later,
doug
Platinum
The metric and SAE are separated, new stuff in drawers & labeled. "Recycleable" fasteners in cookie tins, also separate and labeled as to sizes as well.
But also a few large peanut butter (just clear plastic containers) jars, metric or SAE, further labeled as G.O.K. jars...
"God Only Knows!" Nuts 'n bolts, washers, plastic caps, springs, clips...
Legal Bill
Bass Pro Shops sells their store brand tackle storage boxes in two sizes. During the holidays, they usually sell them at a big discount. Like four for $10. They come with compartment dividers and you can arrange the compartments to fit your hardware and maximize the capacity of each box while keeping your hardware perfectly organized. They are semi-transparent and you can just write on them with a magic marker. Then you can stack them, with the label side facing out, on your shelves.
equiprx
Later,
doug
I have stacks and stacks of small parts drawer cabinets, about 30.
They each carry between 15 and 60 drawers per cabinet.
Most are unlabeled but I know where everything is, for now.
LarryK
I have the Harbor Freight trays mounted to the wall and some 6 multidrawed cabinets. None are labelled so I have to look each time. Whatever I work on, I just pile bolts on the bench. One of my earlier bosses at a Jag shop told me I should put them on the bench in the order I took them off. Told him it wasn't necessary as they only go in one place. But at home, I do the same, but if I loose one have to go thru the storage. As Doc does, ASE and metric separated.
John Turney
I have the little plastic trays from frozen entrees that I put parts in when I'm working on something. Helps keep them together.
I have some multi-drawer cabinets that have new nuts, bolts, screws & small stuff labelled. Used nuts, bolts & screws go on a pie tin if they look to be reusable.
AUSMHLY
Harbour Freight storage box.
They have dividers that are moveable.
LarryK
I have a few of them, won't fit in the cabinet drawers.
F TR2/3/3A Storing painted parts Triumph 7
BoyRacer Rig for storing chassis on its side Austin Healey 8
Csarneson Storing a newly rebuilt engine Austin Healey 25
BN6_2197 Storing side screens in a BN6 Austin Healey 4
S TR2/3/3A Storing a tr3 hard top Triumph 3
L Storing master cylinders Restoration & Tools 9
P storing my midget for the winter Spridgets 6
trrdster2000 Storing, what mommy did't tell you Triumph 2
P Storing for Winter MG 4
T Storing Car for Winter Restoration & Tools 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
S TR2/3/3A ¼ fine square nuts Triumph 7
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
shadowfever Midget seat nuts and bolts Spridgets 2
A BN7 Front Hub Stud Nuts Austin Healey 5
Z Lug nuts for Minitor rims Spridgets 1
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
D Rear Brake Drum Nuts Austin Healey 15
Lin Water Pump torque value for nuts on studs Austin Healey 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
J TR2/3/3A caged nuts problems Triumph 12
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Rob Glasgow Rear Hub Nuts Austin Healey 11
D TR2/3/3A More small nuts [ and studs!] Triumph 2
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
banjojambo TR2/3/3A TR3A Re-torquing Head Nuts Triumph 7
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
Lin Rear Axle Hub Nuts Austin Healey 3
R TR2/3/3A 1961 TR3A's Nuts, Bolts and Screws Triumph 5
C MGB How do you remove "speed nuts"? MG 9
Bob_Spidell Re-torquing Head Nuts Austin Healey 4
D TR2/3/3A Cage nuts, attachment Triumph 6
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
maxwedge5281 healey road wheel lug nuts Austin Healey 7
NutmegCT Loosen those nuts! Restoration & Tools 5
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
S Torque setting for U-Bolt nuts Austin Healey 12
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
S TR2/3/3A caged nuts on the fenders Triumph 9
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
R Engine crank shaft nuts Austin Healey 1
jfarris TR2/3/3A TR3 gauge panel and nuts on gauges Triumph 5
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
