gearbox oil
SPRIT3
Hey new member, and new to the spridgets.
I wanted to know how to change and check the oil in the geerbox, on the sprite "assume the midget is the same"
I have to remove the c-head this week on the sprite, as i believe i have a suspect valve "number 4 cylinder" has anyone else ever encounted the same problem.
aeronca65t
To change the oil, warm up the car (drive it) and then remove the bottom square drain plug. After it's fully drained, put the plug back in and remove the (similar) square side plug. Fill the trans with oil thru the side plug hole until it sightly overflows out of this opening. You may need a small pump to get the oil in this hole. You can also use a long hose and funnel. Either way, it may be messy.
For 1275 cc cars (and older) use motor oil such as 10W-30 or 20W-50 (depends on local temps). For newer 1500 cars, use Gear-80/90 oil.
Biff
Welcome to the group. Since you say "sprite" I'll assume that it is a 1275 or 1098 engine, and yes possibly a 948, however, dosen't matter, if the car has been run hard and long with the heater valve turn off it is possible from the heat build up to accelerate the burning of the exhaust valve. Not enough valve clearence (too tight) will also hasten it's burning.
As to the tranny oil, any good non detergent, mineral base oil from 10w to 50w is usuable. Do Not use any gear EP type oils as they will make short work at eating up the baulk/synchro rings and bushings in the tranny.
Dr_EluSivE
So you are supposed to run regular Motor oil in the 1275 trannys? I have always been told to run gear oil so thats what i always put in. Last time i used 75wt synthetic castrol gear oil. Should change it to engine oil? When i got the car there was No oil in it and it had/has syncro problems with 3rd, after putting the synt gear oil it it got better but didnt solve it. I was gonna swap transmissions but do you think Motor oil would help?
Dr.
S
SPRIT3
Thanks for the help, I changed the oil with no problems. As i have said i had a mini for the past 3 yrs so toping up transmition was never a problem, as the engine sat on top of the geerbox, and uses the same oil.
If anyone has any tecnical questions about the a series motor i have had them all, throw them at me, becasue i have been wasting yrs away on these oil dripping engines.
aeronca65t
Gear oil is used in the 1500 all-syncro trans only (in newer cars).
Older cars with the non-syncro first gear trans should use motor oil. When I say "older", I mean 1275 cc and before.
You might want to try Red-Line synthetic motor oil in your trans....I've heard it works well in the rib-cage trans.
C Gearbox oil British Motor Corp 3
S Add ZDDP to gearbox oil? Austin Healey 29
Lin Gearbox Oil Austin Healey 4
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R Gearbox and Overdrive Oil Level Austin Healey 18
ckeithjordan TR2/3/3A Gearbox Oil Improvement Triumph 7
D gearbox and OD oil drips Austin Healey 23
B TR2/3/3A Gearbox/OD oil Triumph 12
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
C 3000 gearbox oil Austin Healey 4
K TR2/3/3A 70/90 Gearbox oil and Synchros degrading? Triumph 5
Lukens Best gearbox oil... with overdrive? Triumph 16
P Engine & Gearbox Oil Austin Healey 3
memphis Gearbox Oil Seal Austin Healey 9
memphis Gearbox Oil Austin Healey 15
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
mgnewbie Oil dripping from gearbox MG 5
nicko oil in gearbox Austin Healey 10
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
A Vexing gearbox oil leak Austin Healey 5
C Need info on gearbox and rear end oil for midget Spridgets 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
R Gearbox oil 100/6 Austin Healey 5
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
D Gearbox Oil Lotus 7
OregonTR4A Adding gear oil to the gearbox? Triumph 8
R gearbox identification help & required gearbox oil Spridgets 4
HEALEYJAG BN1 Gearbox oil Austin Healey 9
J Gearbox front oil seal Spridgets 8
Wana Gearbox and differential oil change Austin Healey 8
B gearbox oil Triumph 8
mylillooker Gearbox Oil/Fluid/Grease Spridgets 6
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Woodie gearbox oil Spridgets 13
C Gearbox Oil leak? MG 10
G Gearbox oil leak? MG 3
dkj313 76 gearbox oil MG 3
DerekJ Gearbox oil level and over-filling Austin Healey 11
Z Gearbox oil and other notes by chris dimmock Austin Healey 2
B Wedge TR8 Gearbox Oil Triumph 5
sparkydave Gearbox oil question Spridgets 4
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
TNMGB Checking/adding gearbox oil?? MG 34
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
J Gearbox Oil Fill? MG 16
