Gearbox Oil
memphis
Hi All,
What is the current recommendation on gearbox oil? Use 20/50, same as engine or 60w? I did read non detergent is best.
Looking forward to the current thoughts on this.
Thanks,
Bob
Donny_L
I asked the same question not to long ago and the most common advice I got was to go with 60wt VR1 racing oil in both engine and gearbox.
Keoke
:thumbsup:---------------------Keoke-- :laugh:
memphis
memphis
Thanks Guys!
60wt VR1 it is!
Is there a special tool to remove the large nut on the overdrive?
Thanks!
Bob
There is a special tool that hooks into the notches on the big brass plug. British Car Specialist sells it for about $50.00. The smaller one with the square hole can be opened with the ratchet (a little sloppy fit) or a BCS sells a length of square metal that will fit the axle filer hole. As I found out recently, both must be removed to empty the gear box with overdrive.
Keoke
Is there a special tool to remove the large nut on the overdrive--
--Yep but it is pensive. . Try a small block of hardwood and a hammer it will come lose-Keoke
John Turney
Thanks!
Bob
It depends. My original nut had the notches around the edge and I made a tool to take it off. When I had my transmission and overdrive rebuilt, they replaced it with one that had a 1 3/16 hex on it.
Legal Bill
A few threads ago, someone posted a link to an interesting write up about O/D oil. The write up concluded that 30 weight non detergent was the best bet. I'm not using that in my car at the moment however.
grover
I thought that I had read in several places on the forum to use Red Line MT90. That's what I use in the SE-R LeMons car. It's funny nowadays trying to find "GL4" in an auto-parts store.
Anyway, I was planning to use MT90. Has that advice changed?
Grover
Michael Oritt
Grover--
Redline MTL and MT 90 are both GL-4 oils which are appropriate for gearboxes containing yellow metal.
I use MTL in both Healeys but they have Toyota boxes (non-OD) and don't know how that would work out. I'm sure someone will have input.
jimmyr
Member
Just changed gearbox oil in my 100/4 and used Valvolene 60W VR1 racing oil. Shifts nice and the oil weeps have stopped.
richberman
Questions:
1)Is that synthetic or conventional?
2)Is the 60W VR1 appropriate for Philadelphia weather or just those nicer climates where you all live? :wink:
rich
abarth69
I would of thought that 60w oil would be to thick. Since new it only called for
30w
Cheers
Mark
C Gearbox oil British Motor Corp 3
S Add ZDDP to gearbox oil? Austin Healey 29
Lin Gearbox Oil Austin Healey 4
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R Gearbox and Overdrive Oil Level Austin Healey 18
ckeithjordan TR2/3/3A Gearbox Oil Improvement Triumph 7
D gearbox and OD oil drips Austin Healey 23
B TR2/3/3A Gearbox/OD oil Triumph 12
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
C 3000 gearbox oil Austin Healey 4
K TR2/3/3A 70/90 Gearbox oil and Synchros degrading? Triumph 5
Lukens Best gearbox oil... with overdrive? Triumph 16
P Engine & Gearbox Oil Austin Healey 3
memphis Gearbox Oil Seal Austin Healey 9
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
mgnewbie Oil dripping from gearbox MG 5
nicko oil in gearbox Austin Healey 10
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
A Vexing gearbox oil leak Austin Healey 5
C Need info on gearbox and rear end oil for midget Spridgets 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
R Gearbox oil 100/6 Austin Healey 5
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
D Gearbox Oil Lotus 7
OregonTR4A Adding gear oil to the gearbox? Triumph 8
R gearbox identification help & required gearbox oil Spridgets 4
HEALEYJAG BN1 Gearbox oil Austin Healey 9
J Gearbox front oil seal Spridgets 8
Wana Gearbox and differential oil change Austin Healey 8
B gearbox oil Triumph 8
mylillooker Gearbox Oil/Fluid/Grease Spridgets 6
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Woodie gearbox oil Spridgets 13
C Gearbox Oil leak? MG 10
G Gearbox oil leak? MG 3
dkj313 76 gearbox oil MG 3
DerekJ Gearbox oil level and over-filling Austin Healey 11
Z Gearbox oil and other notes by chris dimmock Austin Healey 2
B Wedge TR8 Gearbox Oil Triumph 5
sparkydave Gearbox oil question Spridgets 4
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
TNMGB Checking/adding gearbox oil?? MG 34
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
S gearbox oil Spridgets 5
J Gearbox Oil Fill? MG 16
