General question about 1994 XJS
ricknussey
Hi. I am a new member from Ontario, Canada with a 94 XJS (6 cylinder)that I bought for touring around in. Seems like a great car. Are there any problems that I should look out for. I have never owned anything but North American built cars.
Any info would be greatly appreciated.
bmurphy7369
Welcome to the forum. I haven't owned an XJS, but I did own a '93 XJ6 which also was a great car. Which engine do you have, first of all? The 6 cylinder engine gave me only two problems. The air temperature sensor and the oxygen sensor.. when these go, you will think your fuel system is dying a slow and painful death. Luckily the parts are inexpensive and easy to change.... I am not sure about the V12, hopefully the same could be said. I recommend changing them out unless you know that they are fairly new. Also if you have inboard rear brakes (I can't remember if your car does) check the pads right away. If these wear and cause rotor or caliper damage, the full inboard brake job is costly and difficult for most people. Beyond that, I can't think of much, maybe treat your leather with hide food and keep your car garaged if at all possible... Jaguars and moisture don't generally make a good combination, hence all the electrical system nightmare stories you may hear. Enjoy your XJS, beautiful machines.
Brian
vettedog72
B:
I appreciate your comments on the XJS. I found moistre problems with BMW. So many connections, even the fuse connections were a problem in Louisiana. I had a few boards fail as well: head lights were controlled buy electronic boards and one other that escapes me at this time. Never had any problems in the Atlanta GA area.I guess your comments about the brakes is true for all Jag inboard's? Buy the way, I found a product that really seams to work for electronic connections; it acutally removes oxidation and leaves a protective barrier.
bmurphy7369
Vette,
I think that the salty air is the key (closer to the gulf in Louisiana). I have always tried to believe that Jaguars never had much of a chance from the start, receiving a double-dose of salty climate while awaiting shipment in England (sometimes long periods at the dock, then again at the East Coast port of entry awaiting distribution throughout the U.S.). Definitely, Georgia is one of the better locations to find a rust-free car, probably with less problems in the electrical area... By the way, what is that product for electrical connections? Since I don't feel like running a compression check or tuning Zenith-Strombergs ( /ubbthreads/images/graemlins/pukeface.gif from the anxiety of the task) today, that would be a great project for the '75 XJC.
D TR4/4A General header question Triumph 6
P TR2/3/3A General Restoration Question. Triumph 20
Mowgli81 General Brake Question & repair manual Austin Healey 25
P General engine question Triumph 5
J MGA MGA - general question on buying one MG 8
Atrus General intake manifold question Spridgets 10
B General Spridget Driving Question Spridgets 18
Howard_The_Duck General Engine Question MG 7
jaybird New owner general care question[s] Restoration & Tools 10
C XK120 Interior... and Interiors in General Jaguar 17
B TR4/4A General exhaust questions Triumph 17
pkmh General Present Attitude: Classic Cars Austin Healey 96
D BT-7 couple of general questions Austin Healey 6
S General Tech fuel line vents in general Triumph 4
E TR6 General Inquiries.....Camshaft and valve clearances Triumph 3
E TR6 Crankcase venting and general tuning advice? Triumph 29
gbtr6 TR6 Couple of general resto questions Triumph 4
J Chassis general reassembly sequence Austin Healey 17
M discussion on wheel backspacing in general Spridgets 17
I General air conditioning questions Triumph 4
S MGB-GT New MGB GT owner, looking for some general advice. MG 18
T general "classic" mini info needed British Motor Corp 6
K Break in Oil...What's the general consensus? Triumph 7
Alan_Myers GT6 Please talk to me about Rotoflex, GT6 in general Triumph 10
Sherlock General Motors... Huge News Other Cars 43
gsalt57tr3 Need a good book for general restoration Other British Cars 3
8 General Rant! MG 9
B LBC leaks in general MG 5
D General Purpose Cleaning Restoration & Tools 1
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
