GT6 GT6/TR6 rocker shaft oil problems.
skikir
I was working on my TR6 which has a GT6 engine in it (That will change) and realized that the rockers are not getting oil. The car had been sitting for 18 years before I got it and though I changed the oil and filter before I started it I'm wondering if there there is a oil gallery plugged or ? and what would be the best way of clearing it or if this is a common occurance and if anyone had encountered it and what thay did for it. Short term I think I try getting an externa rocker shaft oiler from one of the big houses but I am afraid the cam shaft is not getting oil either. What to do What to do?
piman
Hello Skikir,
you need to find out how far the oil is getting,
remove the plugs, rocker shaft assembly and crank the engine over and see if oil is coming out of the oil drilling in the head. If not then at the rear of the head is a 1\2" A.F. set screw, remove this and try again. If there is oil there the blockage is in the head and you may be able to clear down from the top to this drilling. I suspect that it is more likely to be a problem within the rocker assembly itself.
If there is no oil from this drilling you will need to remove the head and check both the block to the lower gallery and up from the head face.
Good luck,
Alec
S
skikir
Thanks Alec. I don't know exactly what did the trick but I did remove the set screw and blew air into it. I had air come out some of the rockers and air come out up from the bottom of the engine. ran engine and got no oil coming out of the set srew. Took off rocker assy and blew air down the gallery. cranked engine and finally got oil. Examined rockers. Whoa! there was about a 1/8" gap around the rocker shaft. Ordering new stock shaft and luckily I have enough horded lightly used rockers to build up a set for use on this beater engine for awhile untile I get around to pull the engine out of my other car.
piman
Hello Skirir,
a handy access point, and that is the one used if you want to add an extra oil feed to the rockers.
Sounds as though the engine has been starved of oil for some time in that area, must have been noisy.
Alec
MDCanaday
A lot of guys like to run the added oil feed line from the pressure switch up to the head. its available as a kit and takes only a few minutes to install. Boy will it ever oil then!!!I like mine cause I just couldnt get enough oil to the top end after a rebuild.(I suspect that the severe head planeing caused the oil holes to missalign badly).
MD(mad dog)
dklawson
I added the external oil feed line to my GT6 years ago and it made a big difference. TRF used to sell them... I assume they still do. It's a good investment.
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
glemon GT6 TR6 GT6 Quoted HP More Triumph Trivia Triumph 1
W GT6 GT6 / TR6 Rotor Options Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
hymodyne GT6 TR6 in a GT6 Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
SCguy GT6 GT6 or TR6 in Nor Cal Anyone interested? Triumph 1
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
S GT6 GT6 Head on TR6 Block Triumph 1
F GT6 GT6 Clutch Kit advice, as bad as the TR6 kits? Triumph 5
Alan_Myers GT6 Free GT6 body shell, SF Bay Area. TR4 & TR6 Triumph 1
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
michalotti_tr GT6 Engines: TR6 vs GT6 Triumph 14
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
S GT6 GT6 engine in a TR6 Triumph 3
svtmikey GT6 TR6 engine parts in a GT6 Triumph 9
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
nathandarby67 GT6 Are GT6 oil filters the same as TR6? Triumph 1
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
