Spitfire GT6/Spitfire Heater Box Mounting
UmmYeahOk
Can anyone please tell me how I should install the heater box? I wasnt the one who removed it, so I have no idea how to put it back in. I think its supposed to mount up to the firewall, but I cant see how without drilling, and logically, if it was removed in my driveway, mounting points should still be there.
Will_Ringrose
There should be 4 bolt holes on one side the side with the inlet and outlet pipes on it, opposite side of the fan motor. Those 4 bolts should line up with 4 oval shaped hole on the firewall. The 2 water pipes should come out the firewall thought the larger holes underneath.
71MKIV
with squishy foam seals around the water pipes and the fan intake. The bolts go through the firewall from the engine side and hold the heater box to the firewall.
Weatherstripping around the fan intake, and pipe insulation around the core pipes would be a quick/locally sourced/easy replacement for those seals.
Darwin
Bronze
The 2 bolts to the right of the regulator are the bolts for one side of the heater box. Should be 2 more on the passenger side, same location.
UmmYeahOk
UmmYeahOk
Ok, thanks. Since factory concourse GT6es are rare. I wasnt sure if what he had was in the correct place. I didnt see where it could bolt up to on the passenger side until today. I guess I just needed to lean more and have my head at a better angle. (couldnt see over the battery box) I currently have the driver side bolt up area in use. Where should this lovely unit be installed instead? I was certain it came off the firewall originally
Will_Ringrose
It did come off the fire Wall, I remember on mine having a small tab stop welded on my firewall, bent out 90 degrees that had 2 bolt holes though it. Something like this
This is in between the pedals and the heater box.
I'll try and grab a photo of mine tomorrow.... (warning my car is not pretty, but it runs)
UmmYeahOk
UmmYeahOk
That would be great, thanks.
Dont worry. Mines pretty but DOESNT run. ...According to the town, that makes it a JUNKED VEHICLE. In other words, your car is better than mine.
UmmYeahOk
UmmYeahOk
TR_Jim said:
Does this help?
Not really, because that means that I would have to drill. But I was sure I was the one who removed it. And I thought I removed it from there. After all, due to the length of the wiring, where else could it go? But I guess those holes are for the heater core, because they match the others on the other side. But at least this explains why it was difficult for me to align the bolts.
We didnt bondo over, or weld shut the holes. I wonder where they could be.
dklawson
If I remember correctly, your Mk1 is close to ours in the production run. On our car there is no special bracket for that relay. Instead, there is at least one hole on one of the gussets next to the clutch or brake master cylinder. The relay attaches to that hole. I don't have pictures of that area but if you look at those gussets I think you'll find the hole I am talking about.
71MKIV
Since there's threads in the heater box there's no reason that the bolt that holds the heater in couldn't do double duty and hold the relay too. In fact that might be why you put the relay back there.
dklawson
I checked yesterday. On our Mk1 the inboard gusset next to the brake master cylinder has two clearance holes for mounting the relay.
D Spitfire GT6/Spitfire heater Ducts Triumph 3
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
W Spitfire Spitfire or GT6 wheels Triumph 1
W Spitfire Spitfire / GT6 bonnet Question Triumph 7
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
Reh Spitfire GT6 with Spitfire hood. Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
TheAssociate Spitfire Spitfire and GT6 diffs... Triumph 8
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
