Spitfire spitfire transmission conversion to GT6?
bob67bgt
Hi, anyone know about putting a spitfire (OD) trans into a GT6? bell housing is different and the input shaft as well- can I just switch out these parts? Web site with this info out there? Need some help to get home this week. Thanks- Kevin
Andrew Mace
Unfortunately, it's not really practical. I sincerely doubt a Spitfire gearbox would hold up to the torque of the six, and the ratios -- especially 1st and 2nd -- are much too low (high numerically) for the six as well. All is not lost, as any functional Spitfire OD gearbox would be very easy to sell, but it's not going to work in the GT6.
What's the serial number on the gearbox?
TR3driver
Great Pumpkin - R.I.P
More importantly, which overdrive? If it's a D-type, it shouldn't be too hard to source the parts needed to move it to the GT6 box. J-type I'm not so sure about, but it might be worth talking to ORS to see if it can be done:
https://www.overdrive-repairs.co.uk/
mikecyc72usa
For kicks we tried it about 15 years ago when I had 3 GT6s and a Spit OD trans lying around. After too much effort, the result we knew would happen did: trans disintegrated after about a week of driving. It was a fun "I bet we can fabricate what we need" project with several friends of mine who were very talented. It made it easier that they worked for various Indycar teams (I lived in Indianapolis at the time) and we had full run of the race shops after hours. I'd just source a GT6 OD transmission.
V
vagt6
I installed a J-type in my MKII GT6, it took a bit of fabrication and minor cutting of the propshaft tunnel, and new rear gearbox mounts since the J-type is longer.
Paul Tegler helped me install it, it's documented on his web site. The safron/yellow GT6 in the photos is my car.
https://www.teglerizer.com/triumphstuff/gt6/gt6jtype.htm
Not a project for the uninitiated, but it would have been easier if we had all the parts ready: we had to custom-fab the gearbox mounts out of angle iron, and then fabricate all the wiring. I got the gearbox from Quantumechanics, BTW.
If I had it to do over again I'd install the correct D-type overdrive. It's less expensive, mainly, and requires no cutting (although the J-type required very little cutting, actually). However, the J-type is a bit more robust. But for normal driving the D type is fine.
It's the most useful mod I did to this car, transfored her into a top-end screamer! Just loved that OD.
Let us know what you do . . . and good luck! :thumbsup:
B
bob67bgt
For now we just put a standard trans back in the car. The problem we ran into was the input shaft being way to short when using the GT6 bellhousing. Extending a pilot bush would have been easy but having enough splines for the clutch disc appeared to be a problem we did not want to deal with right now. We'll see if it ever makes it into the car. For now the car is back up and driving! Bob
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
bobmga62 Spitfire Spitfire transmission appears to be locked Triumph 5
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
L Spitfire spitfire transmission Triumph 2
T Spitfire Spitfire/Midget transmission questions Triumph 0
STL_Joe Spitfire Spitfire 4 Transmission Fluid Triumph 7
JPSmit Spitfire Spitfire Transmission question Triumph 2
M Spitfire Spitfire 1500 OD transmission Triumph 9
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
C Spitfire Spitfire transmission question Triumph 2
JamesWilson Spitfire Spitfire O/D Transmission Triumph 3
pjsmetana Spitfire Spitfire Transmission Options Triumph 8
T Spitfire Spitfire transmission cover installation question Triumph 5
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
J Spitfire Spitfire Transmission Swap Triumph 5
JPSmit Spitfire transmission Question Spridgets 7
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
