Spitfire Spitfire / GT6 bonnet Question
Will_Ringrose
For the life of me i can not seem to get my bonnet on my 73 GT6 to line up. The left side no matter how I adjust it seems to be at least a half inch to an inch high. That leads to me my question.
The support / hinge tubs that bot on with brackets. My brackets seem to have been welded on, Is that normal? I feel like the tube is in the wrong spot. if it were to shift a half inch I would be fine.
Thanks in advance,
Will Ringrose
73 GT6
50+ mile daily driver
UltimateQuestion
Yes the bolt tabs are welded onto the tubes (I have two sets and both are welded). Have you tried the adjustment at the hinge point?
tomgt6
Is this the original bonnet?
I am sure it is but have to ask the question.
If you are trying to put a mk1 or mk2 on the car I would assume you would have issues.
Are you sure you don't have a bent part or frame?
W
Will_Ringrose
I have tried to adjust at the hinge. it is as low as it will go and I am still about 1/2 inch too high. It is the Original Mk3 bonnet. So I guess that leaves me with a bent frame or bent tube :eeek:
Any good way to fix this?
The Bug I Got is in to shape to drive at the moment. ( fenders are off and no glass in. doing a quick rebuild on it )
tomgt6
I guess I would do some measurements on the frame and bonnet. As for bending something back, I would guess someone here has some good ideas but I also think that you have to look as some other items.
What I have learned about getting things to line up is that it doesn't seem to make sense. Sometimes you lower the right side to get the left side lined up right or things like that.
It may be a good idea to see if you can find a body man around who would be willing to come and help you with some advice, a few beers and maybe a steak dinner.
V
vagt6
Tom, is the front end suspension heavily shimmed? Lots more shims on one side than the other is a dead giveaway that the frame may be bent.
I found this out the hard way on a GT6. Alignment was spot-on, but only because the suspension was shimmed to the max.
Check your frame measurements.
Good luck, let us know . . .
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
D Spitfire GT6/Spitfire heater Ducts Triumph 3
W Spitfire Spitfire or GT6 wheels Triumph 1
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
Reh Spitfire GT6 with Spitfire hood. Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
TheAssociate Spitfire Spitfire and GT6 diffs... Triumph 8
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
