Spitfire GT6 and Spitfire Dual brake M/C differences
svtmikey
Does anyone know what the difference between the Dual Brake Master cylinders is between the GT6 and the Spitfire?
I notice that in the catalogs I have checked I can get parts to rebuild my Dual GT6 MC, but I cannot buy a new one. There are however, new dual Master cylinders for the Spitfire though.
I assume the difference may be the bore, but can anyone confirm that.
Also has anyone used or sourced a difference make of MC like a Wilwood etc?
Many thanks ahead of time.
Mikey
trrdster2000
Mikey, you are right, the GT6 had a larger bore, for the front brakes had a bigger caliber, but the rear was the same as the Spite. I'm not real sure, but you get different threads on the in lines on later model Spites, (metric). I'm only guessing as I have seen a few Japanese master on our Spites and MG's at car shows and some I've worked on. That said, you just need to find one that fits and use a pressure adjusting valve to get it spot on. May turn out better, but a lot of trouble as you can get the kit and have your master bore redone.
Wayne
svtmikey
svtmikey
I saw the replacement at Spitbits, but I thought (assumed) that was a single, mostly by the picture itself. I guess I should call to make sure....but you're probably right!
Thanks
pware
I see what your saying about it being a single on spitbits. Their is no price for the duel so that means you have to call for avaibility. Let me know if they have them and how much. I too will need one when I get this restoration rolling next year.
Andrew Mace
I'm confused! When I go to the Spitbits web site, I see a listing for:
REPLACEMENT MASTER CYLINDER up to KF20000 .7
ID #: 213690/X
Price: $229.00
That would be the cylinder for roughly 1968 US-spec. "Mk1" GT6, GT6+ and Mk3 through the 1972 model year. They also list the single master cylinder (early "Mk1" up to but not including 1968 US-spec. models) separately. Finally, there is a listing, but with no price, for the late Mk3 cylinder.
The one question I have is if the "../X" in the part number above indicates a replacement by a different manufacturer, as opposed to an original Lucas/Girling cylinder?
pware
I see it too Andy. I guess the only way to find out is to call. Its a bit confusing!
svtmikey
svtmikey
I found this site on the web that outlines some of the GT6 brake specs. According to this the MkI and MkII had the same part number of for the Master cylinders. Doesn't say if they are dual or single, and don't know how accurate this is.
Of course this is European, not NA so I don't even know how valid it is.
https://www.teglerizer.com/triumphstuff/brakecylspecs.htm
Andrew Mace
That chart of Paul's seems pretty good, but it also seems to apply only to the "home market" cars with the single-circuit master cylinders and not US-spec. cars, which did have dual master cylinders beginning with the 1968 model year. And that 213690 dual master cylinder does seem to be NLA from just about everyone (except for Spitbits and their 213690X version, whatever that is).
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
D Spitfire GT6/Spitfire heater Ducts Triumph 3
W Spitfire Spitfire or GT6 wheels Triumph 1
W Spitfire Spitfire / GT6 bonnet Question Triumph 7
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
Reh Spitfire GT6 with Spitfire hood. Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
TheAssociate Spitfire Spitfire and GT6 diffs... Triumph 8
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
