Spitfire GT6/Spitfire E-Brake Button
UmmYeahOk
71MKIV
Two choices,
Give Ted a ring at TSImports, or make one. Piece of bakalite, and five minutes in a drill press with file and sand paper and a little black paint.
Richter12x2
Please excuse me if this is a stupid question, as I am young and ignorant in the ways of the world.
Where and how does one acquire a piece of bakelite? :laugh:
TR3driver
Great Pumpkin - R.I.P
McMaster-Carr carries a wide variety of Bakelite, under the modern brand name Garolite
https://www.mcmaster.com/#garolite/=a8w6u7
Not necessarily the cheapest source, but they have no minimum order, and their shipping charges are quite reasonable.
PS, Bakelite/Garolite would probably not be my choice here, as it's kind of brittle and difficult to machine. Acetal or aluminum would be more appropriate IMO, although perhaps less correct. Actually, the handbrake button on my Stag seems to be something like ABS rather than Bakelite. It feels kind of oily and soft, while Bakelite feels dry and hard.
71MKIV
sorry, My dad was in the electronics biz, and that sort of thing is something you just went digging through the junk box for.
I have purchased lots of garolite from Mcm. You could probably use this stuff
https://www.mcmaster.com/#garolite/=a8wuc8
which is a 1/2 diameter rod, made of fiberglass and epoxy.
It probably comes in the diameter you need, so allyou would have to do is section it,round off the edges a bit, drill a hole in it for the push rod and paint it black.
Kinda salty pricewise, but in the absence of anything else....
I've never had any trouble machineing the stuff, stinks pretty bad, but it does hold a thread well.
TR3driver
Probably just a lack of skill on my part. I'm definitely a rank amateur in front of a lathe.
Richter12x2
My wife's idea was to use a little vacuum cap inside a bigger vaccuum cap, and probably would have worked just fine. The idea we're going with right now is JB Weld. I rolled it into a pipe just about the right diameter and let it set, then used 80 grit sandpaper to polish it round and flat off the back and front, and drilled a hole in the back for the release pin.
We'll see how it holds up!
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
D Spitfire GT6/Spitfire heater Ducts Triumph 3
W Spitfire Spitfire or GT6 wheels Triumph 1
W Spitfire Spitfire / GT6 bonnet Question Triumph 7
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
Reh Spitfire GT6 with Spitfire hood. Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
TheAssociate Spitfire Spitfire and GT6 diffs... Triumph 8
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
