Spitfire Spitfire and GT6 diffs...
TheAssociate
Question about the diff between the diffs...(couldn't resist).
I'm doing a lot of highway driving lately, the low cruising speed and the high rpm is getting to me. I'm thinking of solutions. 5 speed - expensive. Overdrive - expensive for nice, still expensive for worn out.
I've got a shockingly nice running 4-speed in my Spitfire that is almost feels like new in every way. I can't stomach taking out and replacing with an overdrive tranny that might have all sorts of unforseen problems.
So, I am thinking about putting a GT6 diff in its place which I hear is 3.27:1 ratio versus the stock 3.89:1 ratio Spitfire diff.
Firstly, does anyone know if mechanically there is anything stopping me from doing this? Such as the leaf spring not fitting, or the drive shaft not bolting up right? Axle flanges?
Secondly, a question about the ratios. I think it would go quite nicely considering the way it is now you can almost pull away from a stop in second its so low geared!
Any input would be greatly appreciated.
Adam.
___________________________________________________________
1973 Triumph Spitfire.
rotoflex
Standard GT-6 diff was 3.27; GT-6 w/overdrive came with a 3.89 diff.
https://www.britishcarforum.com/tikiwiki/tiki-index.php?page=GT6#_Transmission_amp_rear_axle
They are all the same size & will generally swap, although I think sometimes there is a difference of flange size (which can also be swapped).
The word is that the best diff for GT-6 w/overdrive is the 3.63, which was available w/Spitfires (but unfortunately few US Spitfires).
I wouldn't be too fearful of an overdrive transmission. My D-type transmission is very well behaved. Almost everyone who installs an overdrive loves the thing. I can't recall reports of anyone who removed it & went back after the installation was sorted out. Just make sure you do the installation right - don't skimp on the inhibitor switches which keep you from engaging the OD while in reverse.
TR4nut
A long time ago I went about half way to building a Spit6 with my first spitfire and a GT6 donor car - I did a diff swap and had no problem. I do recall that the GT6 had an extra stud or two on the top that the spit didn't - to fit the spitfire spring to the diff I had to replace the stud(s) with some allen set screws otherwise there would have been an extra vent hole or two on top of the differential. It really was an easy swap, though I can't remember if I noticed the cruising speed difference that much with the swap.
Randy
65 TR4
rotoflex
The number of holes for studs on top of the GT6 differential will depend on whether the diff came originally with a car equipped with the rotoflex or swing spring rear suspension.
The ones which came with the rotoflex suspension have 2 more holes for studs.
billspit
The biggest problem with the 3.23 diff is the carrier is prone to failure. Also, a Spitfire will not really have enough torque to pull a 3.23. So I've been told. I know my Mk I with later OD will not pull a hill in 4 OD.
Andrew Mace
Adam, compatibility should not be a problem with your '73. Unless the GT6 diff came out of a '73 GT6 with the swing-spring setup like your car, it will have six studs at the top. Most people, when doing a swap like this, will cut off the center two studs flush with the top of the case and possibly also cut slots in those studs just to fill the holes. All the flanges will be as your current diff.
You may or may not be happy with this setup. I've heard other Spitfire owners say that they WERE happy doing this. I suspect most of them were Spitfire 1500 owners; 1147s in particular (from the early Spitfires) probably do not have enough torque. And you WILL lose something "off the line" with a 3.27...but 20 mph per 1000 rpm in top gear is nice for economy and lowered stress! (Oh, you will have to either recalibrate your speedometer or grab one from a GT6.)
The 3.63:1 was only available on UK-spec. 1500s with the dual carbs; it's a very rare beast in the US.
TheAssociate
TheAssociate
Thanks for the tips. Rotoflex: I was more referring to the questionable and unknown condition of a used transmission, with overdrive. My '78 had a nice overdrive trans, the overdrive worked when it wanted to and the trans was toast(popping out of gear, bad syncros etc). I like the overdrive very much and would love to have it again, but only if it were mechanically good.
I know the Spit will not pull as hard with the lower ratio, but I plan on installing dual SU's or a new Mikuni which should balance out well(I hope). I'm excited knowing that this will work, even with small sacrifices. Couldn't possibly be as bad as the engine being at 3100 rpm at 60mph.
Andrew: you think it would be 1000 rpm? That would actually make me very happy.
Adam.
____________________________________________________________
CaptDon01
I have an 80 1500 Spitfire w/overdrive and LOVE IT! Never any problem going up hills in 4th and OD. (in spite of what you may have heard, Kansas does have some hills). I've thought of the same swap to lower the RPM even more, or to simply allow for a comfortable 80 MPH cruise.
Don
swift6
Don
Yeah but your hills are not very long and the steeper they are, the shorter they are. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
D Spitfire GT6/Spitfire heater Ducts Triumph 3
W Spitfire Spitfire or GT6 wheels Triumph 1
W Spitfire Spitfire / GT6 bonnet Question Triumph 7
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
Reh Spitfire GT6 with Spitfire hood. Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
