MGA Fuel gauge question
Coastalman
My latest project in fixing the little things that are not working on my 1962 MGA is the fuel gauge. The car has been driven about once a year for the last 20 years for no more than 1000 miles until I acquired it a few months ago. The fuel gauge indicator does move sightly in the right direction when the key is turned on. I have put gas in the car so I know there is at least a half a tank. I figured that the float might be stuck after sitting so long in one place. Today I cleaned off the tank sending unit exterior and ran a wire from the post on the sending assy to a ground. My reasoning was that if I grounded the sending unit, the gauge would read full. It did not move past where it has been moving to. What would be my next step in trouble shooting the problem?
Thanks,
Charlie
Gliderman8
You might check to see if the float has gas in it. I had a similar problem with my TR6.... I knew there was gas in the tank but it read very low. The problem was that the plastic float had fuel in it. I replaced it with a brass float which fixed my problem.
C
Coastalman
I did a test of the gauge by putting a ground lead to the side of the gauge going to the sending unit. My expectation was that the gauge would read full if I grounded the sending unit side. The gauge did not move after the slight forward move that it has been doing when I turn the switch on. Did I have a false expectation that the gauge should read full if grounded?
I'm not going to pull the sending unit until I have another one in hand because I know the gasket will break when I remove it. I'm just checking other parts out before I do that.
Platinum
If the sending unit is stopped in one position for a length of time, the rheostat can get "stuck" in position. Not uncommon with oddly mixed fuel (ethanol) Just had an old Rolls with that issue in Sarasota. Soaked the sending unit in CRC 2-26 for a day, finally got the arm to budge, then worked it GENTLY a bit at a time, got it to move through a complete arc and now it works again.
But the gauge should have gone full travel with the lead grounded. Try the same thing at the gauge itself.
C
Coastalman
That's what I thought! I grounded the wire to the sending unit and, when that produced no result, I grounded the gauge on the down leg side. No movement on the gauge. Someone suggested putting a resistor in line when grounding, but my thoughts, just like you mentioned, was a straight ground would show maximum reading on the gauge. I am ordering a replacement sending unit and try that, but, right now, I don't feel like that is the problem. Most of my knowledgeable friends think it is. A step at a time.
Thanks,
Charlie
Platinum
Resistors are useless. Is it a Lucas or Jaeger? Look to Joe Curto or Nisonger for a gauge replacement.
JPSmit
runs and hides - back to the conversation.
Platinum
:lol:
barneymg
A bit late here, but in case you haven't figured it out yet, then MGA uses a magnetic fuel gauge, and it works backward from what you might expect. Grounding the sender wire drives the gauge to "E". Increasing resistance moves it higher. About 70-ohms resistance takes it up to "F". Higher resistance drives the needle past the "F" mark. Disconnection the sender wire will slam the needle hard against the "F" peg. For full description of the magnetic fuel gauge see here:
Function: > Fuel gauge function - a <
Calibration: > Fuel gauge calibration - a <
Wiring: > MGA fused ignition circuit, petrol gauge <
Trouble shooting: > MGA petrol gauge troubleshooting <
Sender unit: > Fuel sender unit - general notes <
S Fuel Gauge Question Austin Healey 8
N Fuel gauge question?? Spridgets 3
Marvin Gruber MGA Negative grd- fuel gauge question MG 18
T TR2/3/3A TR3A fuel gauge question Triumph 36
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
bighealeysource Fuel gauge question Austin Healey 3
G Fuel Gauge - Sending Unit Question Austin Healey 20
W fuel gauge question Triumph 7
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
