rear leaf spring to chassis bushing
Hawkscoach
Gentlemen,
59 BN4 100/6 full restoration. I removed the "pin" and the grease fittings on each side that secures the rear shackles that the rear leaf springs connect to. I believe there are two bushings on each side within.....I saw they sell these at Moss. (again, for clarity, these are inside the sleeve where the threaded pin goes through. They are steel and seem to be stoutly secured within) Should I remove and replace and if so, how the heck to you get them out? It took me a while to get the pins out. thought I would ask before I start pounding and making a bigger project if not necessary...............
Thanks,
Doug
sorry, number 23 on this drawing. these bushings go into the chassis near the rear frame rail just rear of the axle. they are steel. I would like to know if I should attempt to remove the existing and replace and if so, how do I remove them. Thanks and hope this helps. Doug
I've had my springs off several times. Here's what I think: Is the pin worn? If so, get a new one; lube up with kroil or pb blaster and check fit in bush. If fit is OK, leave bushes in place with new grease.
If the fit is sloppy with new pin, you could probably soak the periphery of the bushes with pb/kroil and tap the inside one out with a drift through the outside opening, then maybe jiggle the outside one with a phillips screwdriver and remove. That kind of thing.
My rear pins and bushes have never shown any particular wear, so I just cleaned everything up and reinstalled with new locknuts and grease.
Thanks Steve. the pins should be replaced as they have some noticeable wear. I would like to avoid removing the bushings, however, I hate to get everything together with wear items replaced, and have an issue requiring disassembly..............and wanted to know what you guys did or have done.
Regards,
Doug
It's a good idea to replace them now. One of those "while I'm at it" things. When I restored my BN2 some years ago I replaced or rebuilt everything except the dampers ("shock absorbers") as they seemed to be fine and not leaking. Guess what I had to do within a year...?
I could only get them out by removing the rear fenders and belting out the inner ones with a big pin punch, then drawing the outers out with threadbar and a socket. They are quite tight.
A similar situation on a different vehicle I have cut through the bushings with a broken off hacksaw blade which releases their grip in the bore then they are easy to tap out. You could also try winding a suitably sized coarse thread tap through both bushings then threading an appropriate bolt in from each end with something in the middle.
Much easier to get back in using a piece of threadbar and nuts/washers. Watch out for misalignment, I had a problem where the bore of the housing was not straight and the pin nipped up each time they were installed. Had to resort to grinding down the outside of the bushings and Loctite to get them aligned.
Leave them be unless they are really worn.
Andy.
as my teenagers say.........OMG
Not touching this unless I have to. I have totally repaired (I think) all the metal, primed and painted the scuttle and was in the process of putting things back on, (suspension, brakes, wiring, transmission, and moving to the back of the vehicle) when I realized I still had these pins in. It took care and patience to remove them so now I will purchase new pins and hope all is good before I consider this. Many thanks for the replies.
Doug
Success! I just thought that I would follow-up so that others may use this information.
I was able to carefully grind off the outer flange on the metal bushing. the metal bushing material is soft. Then, I carefully used a carbide bit to remove some of the inner part of the metal bushing so that it would move. Then, I used a steel rod and "punched" the bushings through. It wasn't as bad as I thought it would be. The only bad thing that happed was that on the first one, I nicked the metal through the bushing and now I am deciding whether it is a big deal and I should tack weld and smooth or JB weld it or just leave it as the new bushings would cover it...........it is only about a 1/16" wide shallow groove. Once I learned how the other side was easy and no damage.
Regards,
Doug
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
N Rear leaf spring brackets Austin Healey 9
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
8 Rear leaf spring Triumph 3
F new rear leaf spring disapointment... Triumph 9
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
Keith_M Bugeye rear leaf springs Spridgets 19
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
Jeepster BJ8 rear leaf springs Austin Healey 2
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
bugedd Rear leaf install Spridgets 7
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
tahoe healey re-arching rear leaf springs Austin Healey 27
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
B rear leaf springs Spridgets 14
prb51 Rear Traction Bars for our Leaf springs Triumph 0
malice Rear leaf swap. Triumph 8
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
AUSMHLY Rear leaf springs Austin Healey 6
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Rear Leaf Springs Austin Healey 30
bighly Replacing rear leaf springs Austin Healey 10
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
