    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
water pump and housing removal
ichthos
Hello,
I need to remove the water pump and housing. I figured it would be simplest to just remove both at once since it is only held on by three bolts. It was fairly simple until I tried to separate the heater return pipe from the housing. Does anyone have any tips on how to remove this?
Thanks, Kevin
Kevin,
The heater return pipe is usually a stainless steel compression-style nut that will back down once you have unscrewed it completely, allowing you to move the unbolted water pump housing forward once it is unbolted. Be careful not to lose the stainless compression fitting that might fall out when you take the housing forward. Leave the water pipe going to the rear of the engine alone and unmolested. May take a little wiggle to break it aloose.
That said, I have seen some aftermarket fittings for this pipe which are really strange as far as how they fit and what they bolt up to. These are usually black colored steel, not stainless. Shouldn't have one of these fittings unless someone changed it out in the past.
Bill
Thanks for the reply Bill. I still don't get it though and need your help. There is a what I think is a threaded pipe fiting into the housing. Another threaded fitting screws into this. When I try to loosen the fitting (stainless steel?) the whole tube moves. The only other option I can think of is removing the two heater hoses at the other end and pulling the whole thing forward so I can get a better look before I damage something. I know this can't be that difficult. What am I doing wrong?
Kevin
Hello Kevin,
the first fitting screws into the water pump body, then the tube is held in that fitting with a compression gland. Hold the first fitting and unscrew the second then the pipe will pull out.
Alec
Kevin,
Alec has it right, do not attempt to remove the piece that screws into the housing. Put a wrench on it to back off the collar that screws down over it, with the compression piece inside. If, when you get it all out, you find that you had loosened the piece that screws into the housing, make certain that you retorque it into the housing before attempting to reassemble, otherwise you will end up with a water leak. Try to avoid using Teflon tape here. The threads in the water pump housing are very old and are often subjected to breakdown from rust. I changed my housing to an alloy one from a vendor in the UK as my old iron one was quite decayed.
Bill
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
T TR2/3/3A Water Pump Housing Bypass Triumph 11
CinneaghTR TR4/4A TR2-4A Water Pump Housing Triumph 7
M TR2/3/3A TR3 water pump housing question. Triumph 4
Tinkerman TR2/3/3A TR3 A Water Pump Housing Pipe Triumph 7
Tinkerman TR2/3/3A TR3 Pipe, Water Pump Housing, Mounts Where? Triumph 15
G Alloy water pump housing Triumph 5
tr6web Water Pump and Housing Triumph 13
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
