orginal BMC radio
bluegrass john
Anyone know if it is possible to change polarity in an orginal BMC to function in a negative ground Healey BJ8 without spending more than the radio is worth ??
Thanks for any advice I can get!!
John
B
bluegrass john
Thanks Bob..............do I find the plug on the outside of the unit or is it internal? I know I have seen some later BMC radios that have a dual slide switch to select the correct polarity. The unit I am looking at purchasing does not have that switch that I can see externally.
Thanks so much for your time,
John
British_Recovery
Bronze
Plug is on the outside of the radio. If you do a Google search for "bmc radio polarity" and select images, there are some nice photos of just what you need a few rows down.
Bob
RAC68
Hi John,
During the span of time multiple models of BMC radios were availability in a number of cars. I would suggest you be very careful that the radio you have can be polarity switched. About a year after the delivery of my new BJ8 in 1964, I installed a new AM BMC radio that remained installed until converting to negative ground about 20 years after. At that time, I attempted to convert the original BMC radio but found, verified by an expert, that the polarity could not be easily changed. The reason given was as has been mentioned, that the case the ground for the radio as is the antenna. Modification would require the internal boards be changed substantially to accept the change. As you indicated, other models of BMC radios had the internal circuitry isolated from the case and, as such, could be altered to operate in a negative ground environment.
I am not sure what BMC model radio you have but I would be very careful thinking it will be easy. Although I still have my original BMC radio, when changing car polarity, I decided it would be far safer if I acquire a negative ground radio that would accept the clear plastic BMC display and install it instead of risking and trying to modify the original. The original has remained on the shelf for over 30 years and I will probably never reconvert my car back to positive ground. The replacement negative ground radio, with the BMC display, is still installed in my original console and is also sitting on the shelf waiting for the time when I ever think of going back.
Bob may be correct and your model may be easily convertible...or maybe not.
Good luck,
Ray (64BJ8P1)
B
bluegrass john
I think you have offered some sound advice; I will take heed and perhaps the way to go is to purchase a radio with the slide switch that offers dual polarity. They are occasionally available on e bay and I am told certain models will fit like a glove !!
Regards.
John
Keoke
Regards.
John
:iagree:---or purchase a later NEG Ground AM / FM look alike radio, as the power output and music quality of the old BMC radios is not that good.
Keoke
Well that intensive a modification is generally not required:
It can be accomplished by simply isolating the radio case and the antenna from chassis ground.
However, this method is not consider safe or recommend.
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
KellyRob BMC GEARBOX 1960 British Motor Corp 2
L BMC A-series: Oil in coolant British Motor Corp 6
K BMC Supplemental Tool Kit Bags Austin Healey 14
O For Sale BMC Service Shop sign Other British Classifieds 3
C BMC Special Tuning Data Austin Healey 9
K MGA BMC paint colour code AL1 MG 2
K BMC paint colour code AL1 [wire wheels] Austin Healey 1
HealeyRick The BMC Story Spridgets 7
HealeyRick The BMC Story Austin Healey 29
HealeyRick "Tuning BMC Sports Cars" Spridgets 11
abarth69 Dry Sump BMC Engine Spridgets 3
I Resource for BMC/Leyland parts for Sprites? Spridgets 15
S Argentinian BMC Ute?? Other British Cars 4
B 100/6 BMC parts manual Austin Healey 12
K Colour Chart for Austin-BMC-MG...Jaguar? Triumph 3
sjuengst BMC affinity Austin Healey 0
theleisure BMC SPECIAL TUNING DATA Manual Spridgets 4
B BMC Training Unit Bus Other British Cars 164
BugEyeBear 1958 BugEye 1st Road Test Vintage BMC Video Spridgets 0
E Tip to remove the BMC on a '70 Midget Spridgets 6
TurnerSports222 Alexander Cross Flow Head - BMC Other British Cars 4
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
H 1965 BMC AM Radio - no sound Austin Healey 5
John Loftus BMC fastener codes Restoration & Tools 10
Howard_The_Duck Posi-Ground BMC radio MG 5
B BMC Comps Dept new book Austin Healey 0
M Crosley with BMC engine-trying to identify it. Other British Cars 6
S BMC registry Austin Healey 12
rovernut Austin or BMC mini logo British Motor Corp 4
78Z check out this BMC/BL history site Other British Cars 3
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
S Radio Antenna Spridgets 5
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
M General MG OEM Radio wiring help MG 4
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
