TR2/3/3A Question on old radio from my TR3
TuffTR250
I've got an old "Automatic Radio model UAF-6270" that was in my TR3 when I got it in 2012. Finally got around to looking at it. I tested it and it is currently set to positive ground and works. I would like to change it to negative ground, the same as my TR3. As can be seen on the pictures below it can be set to either positive or negative ground. However it is unclear to me how to make that change. I don't want to mess up the radio trying to change the ground polarity. I tried turning the "wheel" by the ground indicators on the top cover but it does not seem to want to move. Can anyone advise me of the correct way to change the ground polarity on this radio?
I searched the various Vintage radio web sites but none of them addressed how to change the polarity on this specific radio, and I'm not at all knowledgeable on radios. Thanks!
Bob
Geo Hahn
On mine (which may or may not have been similar) you pry/pull out a plug with multiple pins that then gets re-inserted in a different orientation.
If it will pull out you would then insert per the notation on the case.
T
TuffTR250
Thanks Geo! Did the pull out thing look anything like the round thing in my picture DSCF2023.JPG? I can't tell if that round piece will pull up and out. I don't want to pry up on it in case it breaks it. I will post a picture a little later of the round thng without the top cover over it for a better view of it. BTW, do you have an owners manual for the radio that had the pull out method of changing the ground polarity? Thanks!
Bob
sp53
Did you look for a very small slide switch to go from pos to negative ground on the outside of the case? my old radio had one.
steve
T
TuffTR250
Here is a picture of the ground "wheel" mechanism without the top cover on the radio. Hopefully this is more informative than the picture with the top cover on.
sp53, it does not have a slide switch on the side. I believe the "wheel" mechanism is the ground switch, but I'm not certain, and I don't know how it works.
Bob
Sarastro
This might help:
It looks a lot like your radio.
I see a notch in the circular thingy that is now pointing to the positive-ground symbol. My guess, based on this video, is that you remove it and turn it so the notch points to the negative-ground symbol.
T
TuffTR250
Today I received the Photofact service manual in the mail for the Automatic Radio model UAF-6270. It is purely a Service Manual as stated on eBay, not an owner's manual. However, I found in the wiring diagrams a layout of the the ground section. There was an extra small side diagram showing the "bullets" of the ground with a note pointing to it saying "Rotate 90 degrees for positive ground applications". I appreciate the helpful suggestions on the Triumph forums. Since I wanted to order the Service manual anyway, I decided to wait to do the conversion to negative ground until after I had received the Service manual. I appreciate the suggestions on how this ground conversion works. The radio now works on negative ground. Thank you all!!
Here are some pictures of the ground "plug wheel" on my specific radio
Bob
Sarastro
Interesting. I fiddle with old radios occasionally, but I had never seen that arrangement.
Good that you were cautious. Many of us (ahem!) would just dive in and start prying, and probably break something.
GTP1960 TR2/3/3A Resurrected an old question re: removing old style oil seal Triumph 8
P new "B" with "old" carbs/exhaust question MG 3
jlaird Another stupid question from your old friend Spridgets 18
S old question maybe?, rebuilt engine Triumph 3
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
Mental Old lurker with an old electrical question... MG 10
W Question on polishing up old paint Restoration & Tools 3
M_Pied_Lourd Old Electric Fuel Pump Question Triumph 15
D Question on OLD MG MG 23
jlaird Question, cause I'm old and forget Spridgets 4
nevets question about old old brake fluid color Austin Healey 8
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
