General MG OEM Radio wiring help
mtarcher1
I've acquired a British Leyland (Mororola) radio for my '79 Midget. The car had a radio installed by the dealer when new but that was removed by the original owner long ago...classically, he hung a cassette tape deck below the glove box and put 4 speakers in the car...2 in the foot panels up front and 2 in the boot. The cassette player was gone when I bought the car My intent is just to get an OEM type radio back in the console. I bought the car from the original owner in the early spring. It has 19,000 miles on it. He'd parked it in 1986 to save for retirement but found he just wasn't gonna get to it ever again. After going though a few things, I finally started it in June. With some carb adjustments it has been running great. It's not a concours car but it is in great condition and getting an OEM radio back in it will be a nice touch.
I've spent a bunch of time searching for a manual for this model radio...to no avail. The attached pics show the radio. I could use some help understanding the wiring.
The red wire appears to be the main power since it connects to the on/off knob. It would connect to the 12v behind the console with an inline fuse. I have a copy of the radio installation instructions the dealers used so can see how the power is wired.
What is unclear to me is how to connect the 2 black wires, the brown wire and the brown/yell wire. If this radio is set up for 2 speakers and I have a single speaker in the console, how do I address that?
Any insight is appreciated.
Update: The radio is reportedly from a '74 MGB with 2 speakers.
Mickey Richaud
Mornin'!
You'll need to verify this with a VOM (volt ohm meter), but here's my recollection from waaaay back:
First off, are you sure the radio is designed for two speakers? Is there a switch for front/rear?
Then, red is power input (should have an inline fuse); brown is ground (check to make sure it's connected to the radio housing); two black wires are for the speaker (one should be ribbed/striped - that's for the positive speaker terminal). I think the yellow wire is for the internal light, wired to your light switch.
Hopefully, someone else will chime in as well.
And please keep us posted.
:cheers:
Mickey
M
mtarcher1
Updated info- the radio is probably from a '74 MGB and had 2 speakers.
I uploaded another photo to the first post showing the radio chassis interior and where the wires seem to go.
The radio dial light is powered off the on/off knob. I don't think the radio is lighted until you turn it on....not dimmable nor connected to the dash lights.
Each of the 2 main knobs have a secondary function using a chrome ring knob behind it. I recall from my youth that some radios had a front/rear speaker balance built into one of these secondary knobs.
The multimeter shows zero resistance between the radio chassis and the wires, except for the red which goes to the on/off knob. That red wire to the knob shows no resistance when turned on. I suppose the whole system is grounded through the mounting strap on the back of the radio.
Gliderman8
I have mine (AM-FM) grounded to the nut on the back of the case as shown in your pic #3.
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
H TR6 OEM Connecting Rod surprise Triumph 4
C BN1 OEM Rubber Floormats Austin Healey 1
princetn1 MGB OEM Original MGB Chrome Bumpers MG 14
toysrrus TR2/3/3A OEM TR3 Luggage Rack Triumph 7
J Moss OEM AIR DEFLECTOR ASSEMBLY Does it do anything? Austin Healey 9
5 TR2/3/3A Who was OEM glass manufacturer for tr3 windshields Triumph 1
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
S ride difference oem vs poly bushings Triumph 4
T What to do with OEM calipers? Triumph 8
M Help with OEM Jaguar Parts ID Jaguar 5
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
bcbennett OEM side mirrors still available? Triumph 10
Brosky Crappy OEM Parts Triumph 14
G E-Type OEM hose clamps Jaguar 2
C Non OEM/aftermarket parts suppliers. Spridgets 3
B T-Series vintage new OEM MG mechanic uniform patch 4 sale MG 3
V Where to find an OEM hardtop? Triumph 2
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
S Radio Antenna Spridgets 5
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
1 MGB '66 MGB radio measurements MG 3
6 Spridget Radio/Speaker Case Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
T Wanted Wanted: BE Sprite Original Motorola Radio Spridgets Classified 8
F TR2/3/3A radio mounting plate Triumph 4
H Vintage Radio Austin Healey 9
Zitch TR4/4A Original Radio knobs Triumph 12
M S1 e type radio console Jaguar 2
wangdango BJ8 radio delete plate? Austin Healey 2
Got_All_4 TR2/3/3A TR3 radio console Triumph 30
