Removing Old Radio
Dr. Smoke
Member
Is there any source of instructions as to removing the old radio from my 1966 Austin Healey? I plan on having it restored, but have no idea as to how to remove it?
Dr Smoke
Assume it's a BJ8, not s Sprite? My BJ8 came with a 'stock' radio, a BMC. which was likely dealer-installed (based on the shabby cuts on the console vinyl). You'll need to remove the console, and the shifter boot and knob, but it's otherwise a bunch of screws (4 machine screws under the fascia/dash, and sheet metal screws elsewhere). The four knobs--tuner, volume, 'tone' (hah), etc.--just pull off, and there are two thin locknuts holding the radio to its faceplate (5/8" IIRC--you'll need a deep socket if they're not finger tight). Behind the radio, there are is a bracket on the console that hooks a couple bolts on the radio; with the radio otherwise loose the console can be tilted to free the radio (you have to work it, and the speaker bracket, around the heater's heat exchanger). Hopefully, there are connectors on the power lead (probably fused)--I don't recall if there's a ground lead (probably--you need one because there isn't a robust ground otherwise). The antenna cable has a 'banana' connector that should just pull out.
If it's aftermarket, all bets are off (but should be similar).
One correction (second cup of coffee just kicked-in): The bracket that holds the radio is actually affixed to the gearbox cover, not the console.
One more correction (I haven't had mine out in a while, but it's slowly coming back): The bracket on the gearbox cover hooks the console, not the radio itself. The radio is held in only by the nuts under the knobs, but you have to finagle the console to clear the heater exchanger.
Tinkerman TR2/3/3A Removing old contact cement Triumph 6
GTP1960 TR2/3/3A Resurrected an old question re: removing old style oil seal Triumph 8
K TR4/4A TR4A Removing the old floor mount bolts? Triumph 9
RickB Tricks removing old tenax fasteners? Need 4 tall.. Spridgets 11
Aldwyn Removing Old Sealer? Triumph 13
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
